Main > Monitor/Video Forum
Video amp (RGBs) to boost SCART to arcade monitor
arfink:
as long as your sync is in range and your signal voltage isn't too high, it should just work.
arcadeswede:
--- Quote from: arfink on May 13, 2020, 10:32:59 am ---as long as your sync is in range and your signal voltage isn't too high, it should just work.
What? Doesn't make sense. According to this page, specs for arcade vs scart looks like this:
--- Quote ---Arcade video (standard resolution)
Video amplitude: 2-5Vpp
Video DC offset: yes, as much as a volt or two
Video input impedance: 1k-10k
separate horizontal and vertical sync (most of the time)
sync polarity negative (most of the time)
SCART video (RGB SCART)
Video amplitude: 0.7Vpp
Video DC offset: no DC offset, AC coupled
Video input impedance: 75
sync signals stripped from Composite video (CVBS)
Maybe sync will be fine but voltages for the SCART signals are way to weak, hence the need for amplification.
Just to be clear, I'm talking about connecting a console with RGB SCART to a arcade monitor, not arcade to TV (aka Supergun).
arfink:
Right, I understand that. I'm just saying, if you want an image and you don't want to blow up your monitor, just make sure you have the right sync frequency + polarity (usually, composite negative sync, 15khz) and don't exceed 4-5vpp for your video signal. You can amplify up to that point as needed/desired. If you go over on the shmups forums in their RGB modding thread, you can see that people have committed worse abominations in RGB signal land and been fine.
buttersoft:
Some few arcade monitors will work fin with 0.7Vp-p RGB, most won't be able to boost it and will need an amp. Ultimarc's one will work fine, or if you want to build one a THS7374 is as good, and a THS7314 or 7316 almost as good.
arcadeswede:
--- Quote from: buttersoft on May 14, 2020, 02:48:50 am ---Some few arcade monitors will work fin with 0.7Vp-p RGB, most won't be able to boost it and will need an amp. Ultimarc's one will work fine, or if you want to build one a THS7374 is as good, and a THS7314 or 7316 almost as good.
Ok, good to know!
According to the datasheet of the 7374, it only has a gain of x2 (6db), which equals to 0.7Vpp x 2 = 1.4Vpp. Which is not really enough ???
I found a THS7375 with a 15db gain (around x5.6) which equals to 0.7Vpp x 5.6 = 3.92Vpp. That should be good enough, right?
Btw, does these signals need to be AC coupled going into these?
