Main > Monitor/Video Forum
Wells Gardner K7193 Vertical Bar issue
Ken Layton:
Looks like electrolytic capacitor issue.
Prpl_Turtle:
Ken !! Holy Crap, thank you for responding! That’s what I’ve been thinking too but I’ve done an electrolytic cap change out twice now and it hasn’t gone away ..... any clue which one it might be? Only cap I e only swapped once is that big guy in the top right corner .... I wonder if it could be that one? You know I did notice that I can get rid of it if I turn the brightness down low enough. It disappears but the image on the screen does seem a little dark when I do that ....
grantspain:
you are using a signal generator, do you have another video source you can try
Prpl_Turtle:
Hi grantspain,
I’ve hooked up through a j-pac running crtemudriver and I’ve also hooked up through the MiSTer both vga analogue out and direct video all with the same results
