Author Topic: WWF Wrestlemania artwork scans using a modified flatbed scanner  (Read 10593 times)
mourix
  • Last login:March 12, 2026, 07:46:52 pm
I am restoring my dedicated Wrestlemania cabinet and found a huge lack of resources for it online. I already scanned and uploaded all the documentation, and the artwork is up next! My cab has very good artwork all over, besides the CPO. I took it all apart and got to scanning.
Looking around, you'll find most of the pro's using the HP Scanjet 4600/4670 see-through scanner. The reason for which is the fact it can scan whilst laying on top of artwork. Normal scanners are focused on the glass and have raised edges making it impossible to get a sharp picture.
In the year 2020, the HP 4600 is getting really hard to find as it's a niche scanner from 2003. After looking for a month I caved and decided to go for a DIY alternative. The steps are as following:
1. Get yourself a random 10 dollar second hand flatbed scanner. Look for one with minimum 600DPI resolution, windows 10 support, and look at pics online to see how hard it is to cut the plastic. I went for a local Canon LiDe 110. Take off the top cover first and try to scan a piece of artwork upside down. Maybe you lucked out with a high focus range scanner.
2. If the image is blurry, it's time to take off the raised edges. Pry the removable parts off first. I added tape immediately to prevent dust from getting in.
3. If your scanner is like mine, you need find a way to cut off the raised sides as well. I used an old screwdriver and cigarette lighter to melt it off..
4. Clean the glass and make sure there is no dust inside the scanner. Now the glass is loose we need to find a way to keep it to the scanner. I used a combination of hot glue and electrical tape I has laying around.
5. Profit... If you did not break the scanner in the process of course.
Mine came out well, though. Here is a zoomed in sample scan:
At this point I already scanned and mostly cleaned up all the control panel artwork. I will upload it when it's ready. Any requests? I just want this artwork to be available for everyone.
mourix
Re: WWF Wrestlemania artwork scans using a modified flatbed scanner
« Reply #1 on: April 30, 2020, 10:31:13 am »
First up, CPO. This one took me many hours as it's my first photoshop cleanup from a damaged source. It is not perfect, but a lot better than what was available online before. At this point, I have ordered a print to go on my cab  ;D
Scan:
Cleanup:
mourix
« Reply #2 on: May 18, 2020, 01:22:56 pm »
The CPO got printed and turned out incredibly nice:
Here is the link to the full quality file :laugh:
mourix
« Reply #3 on: May 19, 2020, 04:45:29 am »
CP sides cleaned up nicely as well.
Download link.
« Last Edit: May 19, 2020, 04:51:10 am by mourix »
mourix
« Reply #4 on: May 19, 2020, 04:59:54 am »
The control panel front art is finished too.
Download link.
  • Last login:March 10, 2026, 05:35:00 am
« Reply #5 on: May 19, 2020, 06:39:49 am »
Nice. :cheers:
mourix
« Reply #6 on: October 01, 2020, 08:55:33 am »
Had some time and finished up the marquee 8)
Download.
mike boss
« Reply #7 on: January 13, 2021, 07:11:35 pm »
Amazing.
Well done.
