Main > Monitor/Video Forum
So i got 2 new old 20 inch crt monitors.
Mike A:
I think arcadepartsandrepair.com has pictures of various chassis for ID purposes.
abispac:
cheap chinese crap, but i guess if i ---fudgesicle--- them up at lest ill have tubes to spare.
i found the chassis at ali express
https://es.aliexpress.com/item/32761524828.html
fuchi_jeg:
I'm not sure he was joking.
abispac:
update 1
yellow chassis, was weak, i tested on the regular curved monitor, had good image but i could hear the flyback make some noise everytime i had to adjust the screen, without hesitation, pam....bye bye vertical ic, now i have a vertical collapse , but ive been reading they are easy to repair.So ima get my hands dirty trying to fix it myself, heres a pic before the ic vertical went down.
Green chassis has more power, but, no matter what, i cant center the image, ive played with the knobs for over 2 hours with no luck.
Which leads me to ask:
What can i do to center the image on that green chasis?
Thanks for any advice.
abispac:
--- Quote from: Mike A on April 14, 2020, 01:46:03 pm ---2 more monitors on death row.
Just so you know, i did kill both, on my defense, i got to say , the yellow chassis was weak i did a couple of adjustments on the pots and the vertical went out real fast, the green one , i couldnt center the image so i notice, it had one broken pot and one blew cap, so i replace them now the cap i replaced its shorting out so im not sure what i did wrong. My heat pen or whatever its called in english, failed on me so ima have to wait until tomorrow to buy another one and try to replace the caps again, but one bad thing is i cant seem to find an eschematic.
