Main > Monitor/Video Forum
Sony Triniton kv-2xxxx Rgb Mod
abispac:
So ill bought the resistors today , ill make some test later on and post results.
abispac:
soldered my cables today,tomorrow will test them out, i added 2 resistors for a total of 910 Ohms and 75 ohms that would go to ground.
I do have one question, by just puting all the grounds together, wouldn't that just short the rgb cables as well? and what am i missing?
Zebidee:
You have a lot of spacing there. Doesn't matter much for the 910R in series part, but the 75R terminator (to ground) should be as close to the input as reasonably/decently possible.
Connecting the grounds won't short R-G-B lines to ground because they'll have those 75R resistors there to stop that.
abispac:
--- Quote from: Zebidee on April 10, 2020, 01:56:54 am ---You have a lot of spacing there. Doesn't matter much for the 910R in series part, but the 75R terminator (to ground) should be as close to the input as reasonably/decently possible.
thank you sir, ill fix the grounds before testing.
abispac:
So i installed everything , fired up the tv, and its was a succesful failed attempt, the tv started making alot of clicking noises, no image but just like ghostly images with lines on top....aaaaaa ---fudgesicle--- it, not worth the time, its way to big and too heavy for an arcade anyway, so ill just get another smaller tv and try again...thanks for your help guys, case closed on this one.
