Main > Monitor/Video Forum
Flickering and wrong picture alignment SONY PVM 1454QM
Pages: << < (2/2)
buttersoft:
crt_emudriver allows you to output composite sync directly, so you could try that. If that doesn't work tho, then you do need a way to combine sync, and the extron is about as good as it gets. One of the dip switches will bypass sync processing, which will remove any lag and and also disable the h-shift control because it's no longer being used.
You'd have to rely on the options in the PVM's service menu then, but those should work fine, if the set is in good condition.
Pages: << < (2/2)
Go to full version
