Main > Monitor/Video Forum
electrohome g07 Vertical collapse.
Pages: << < (3/4) > >>
abispac:
--- Quote from: grantspain on April 03, 2020, 07:48:30 pm ---ok show us a photo of how you have wired up the regulator
thank you sir.
abispac:
--- Quote from: behrmr on April 03, 2020, 07:24:08 pm ---Just about anything wrong in the 400's can cause collapse
can you elaborate on what this means please?
behrmr:
--- Quote from: abispac on April 03, 2020, 09:06:38 pm ---
Look at a G07 schematic and at the physical PCB.  You'll see parts numbered in the 400's.  Failed parts in that section is mostly where vertical collapse can happen.  Also IC501 can fail and cause all kinds of problems.
abispac:
i give up,took it to a pro.
Mike A:
Hopefully it is not the same pro who didn't finish fixing your other monitor and handed it back to you.
Go to full version
