Main > Monitor/Video Forum
Kortec KT-2914F - Which graphics card
Pages: << < (2/2)
fuchi_jeg:
Check calamity's website for compatible graphics cards. It depends on your application. R9 series are amongst the most powerful, but wont fit all PC cases. Search for a passive cooled if fans noise is a problem. Search for half height if you have a SFF PC.
bobbyb13:
--- Quote from: fuchi_jeg on March 23, 2020, 03:07:55 pm ---I think you will be happier with crtemudriver and an AMD card. Its last restricting, and probably less expensive.  There is a slightly higher learning curve though.
This can be absolutely correct, although it depends on how much you already know and how much time you have to spend on setting things up (and what you think that time is worth.)
I finally had great success with a Radeon HD 7670 4gb and Calamity's drivers (after I spent numerous hours with no luck at all with a Sapphire 5450 however) in one cabinet.
Setting up the arcade vga and my Kortek in another cabinet was under an hour.
YMMV
scottjk:
Thanks Bobby for the input. I'm placing my Arcade VGA order after I click post. I just want to get things up and running. I'm afraid if I spend any more time I'll just shelve this again.
bobbyb13:
You can handle it so don't lose faith.
Graphics card/driver genius and support from both Calamity and Andy are superb if you need help.
Pages: << < (2/2)
Go to full version
