Main > Project Announcements
My new cabinet
<< < (3/5) > >>
fgh:
Thanks for your comments, guys! I've added some build pics and explanations in the second post, above.
javeryh: Thanks for your kind words! I do like the visual impact of having all the game graphics.
Greenman: Thanks!
Yotsua: I do have a small kickplate at the bottom, and the distance is not too bad due to the screen angle. But it's a concern for sure. I almost named it carefulcade as a joke! I might make a detachable plate to cover the whole screen eventually.
Laythe: Thanks again! At one point years ago I was considering names, and shapeshifter was one of the hot candidates haha.
Wzrd0803: Thanks!
Firedance: The speakers on the floor are temporary, I have TV speakers on the CP and will have a larger speaker or small active sub inside.
DaOld Man:
Good build! I, too have never seen a monitor in the bottom part like that. I like that idea however I see what yotsua is getting at. Id be afraid someone would run a foot through it.
yotsuya:
--- Quote from: fgh on March 22, 2020, 05:28:47 pm ---Thanks for your comments, guys! I've added some build pics and explanations in the second post, above.
Greenman: Thanks dude!
Laythe: Thanks again! At one point years ago I was actually considering names, and shapeshifter was one of the hot candidates haha.
Wzrd0803: Thanks!
Yeah, I’ve seen enough kids and adults play video games and know that they call it a kick panel for a reason. Never put stools in front of it unless you put some thick protective plexiglass in front of the screen.
rablack97:
check it blood, homie put the plexi coal upside his head, he didn't trip. handled up cold like a muthaaaa.......shiiiiii
Translation:
Yes i did the same for this one a few years ago, just cut some plexi and use that.  You dont need a kickplate.  Im not sure how you mounted the monitor but i would have done it more like an inlay with extra space along the edges, that gives you enough room, to lay the plexi inside the pocket, the lay the monitor face on top of that and then use straps to mount the monitor to the bezel.  I took this to multiple exhibitions and the bottom screen is still in tact.
Nice work man, good to see people think outside of the box and use modern peripherals, the wow factor is right when you got the bling on it....
Coin doors get the middle big one :) #wherethetokensat
firedance:
Thought they would just be temporary, great job  :D
Navigation
Message Index
Next page
Previous page
Go to full version
