Arcade Collecting > Restorations & repair
English Mark dart super 6 plus 2
<< < (2/2)
Rahl_28:
When you talk about the spider is that the pressure point plate?  Or is it the frame that’s holds the segments? The segments do not have the plus, they have a few edges that stick out and I believe they’re from  the galaxy style. Here’s a few pics of the boards. As of right now everything works as it should. Is it possible to change some circuit boards and update this to a galaxy?
jimmyfloyd:
correct. The Spider holds the segments. You do have the galaxy style, which is the newer version. This is good for the potential upgrade. There was an upgrade kit put out by Arachnid, but probably won't find it complete at this point. here is the Flyer: http://antelopearcade.com/files/Ken%27s%20Korner/Arachnid%20Galaxy%20Conversion%20Kit%20Flyer.pdf
You could probably put one together. At minimum you'd need the main board, wiring harness, Target Interface and 6 wire RJ-11 cable, and maybe the power supply. I have most of these, except the wiring harness and power supply.
Here are the documents on your board if you don't have them: https://www.arachnid360.com/2019-commercial-products/legacy-dartboards/6000-series-dartboards/
Rahl_28:
Thanks for the help and info, I’ll let you know if I need anything, I might change everything out and upgrade. Will the tv still work if I do that?
jimmyfloyd:
It should. The board just needs a monitor that supports an AV input to work, which the original should. Both boards support AV.
Also, the wiring harnesses are very similar in inputs, so there is a small chance you could modify your current one to power up the game. Unsure what the Coin Credit board would do in that case though. You could always make your own harness too if you did not need the coin section to work. I have a custom made harness for bench testing the boards.
MikeMango:
It's a shot in the dark but I need the matrix for this if anyone still has one!
Navigation
Message Index
Previous page
Go to full version
