Author Topic: quick noob question  (Read 1184 times)
saltypenguin
  • Last login:March 07, 2004, 11:30:02 pm
quick noob question
« on: February 17, 2004, 01:08:13 pm »
Couldn't find the answer in any of the examples, but maybe that's because it's well known or obvious. :P Anyway, I'm getting ready to do my control pannel and need to know what size holes to drill for the joystick and buttons.  I have Happs buttons and Super Joysticks. Thanks.
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
Re:quick noob question
« Reply #1 on: February 17, 2004, 01:12:07 pm »
1-1/8" is your best bet for buttons and sticks
fredster
  • It's all good!
« Reply #2 on: February 17, 2004, 01:40:04 pm »
Happs has diagrams on their website to show the locations.
1 1/8" spade drills work the best.  Make sure you have a pretty good 3/8" drill!
saltypenguin
« Reply #3 on: February 17, 2004, 01:40:57 pm »
Thanks a bunch guys
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
« Reply #4 on: February 18, 2004, 01:48:44 am »
I dont have a link for quick reference, but there are templates you can download that will make your button alignment PERFECT!
Maybe someone can post the link. I'm just lazy tonight and don't feel like diggin lol
groovy~
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
osiris
  • Last login:August 29, 2004, 03:24:02 pm
  • YUb YUb
« Reply #5 on: March 04, 2004, 07:12:48 pm »
Do the spade bits really work that much better? I used a "normal" (m shaped) circular drill bit, and it worked like a charm. Of course that might be because i used a drill press, and MDF.
Isn't an anarchist party counter intuitive?
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
« Reply #6 on: March 04, 2004, 11:30:01 pm »
I think that some of us may use hand drills and do not have access to drill presses.  I may be wrong, but I don't think that a normal circular drill bit that size would fit in most hand drills.  However, I am sure that using that bit along with a drill press would work great.
garyh
  • Last login:January 26, 2011, 02:30:17 am
  • If God rides a Harley then the devil rides an LC.
« Reply #7 on: March 05, 2004, 03:41:58 am »
sTyLeS
  • Last login:January 25, 2021, 01:11:12 pm
  • I fling poo...
    • DragonCade
« Reply #8 on: March 05, 2004, 03:30:19 pm »
Forstner bits are great, but cost a lot more than a spade bit. I used a spade bit on both the control panel and the plexiglass overlay, and it worked flawlessly.
A recommendation for using a 1 1/8" spade on plexi: Make sure you "sandwich the plexi between two pieces of wood when drilling to prevent possible cracking...and go slow.
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #9 on: March 05, 2004, 04:09:06 pm »
I used a spade bit and it worked flawlessly. Try to use an electric drill if you can. It has more torque and greater RPM = claner, faster hole...
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
CitznFish
  • Last login:May 26, 2023, 12:36:44 pm
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #10 on: March 05, 2004, 05:15:30 pm »
electric, as opposed to gas powered? ;)
I know, I know..as opposed to battery operated, but that's still electricity and I can't resist being a smart ass today. :)
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #11 on: March 05, 2004, 06:08:14 pm »
you obviously never had to use a handcranky drill, uphills (both ways), in 3 feet of snow... Gas powered drills... luxury I tell you!
rampy
