Main > Monitor/Video Forum
RGB Mod TV - Jumping off point
Pages: << < (5/7) > >>
pbj:
You know you can put resistors in series....right?
abispac:
--- Quote from: pbj on April 07, 2020, 11:02:45 pm ---You know you can put resistors in series....right?
no i dont, can you tell me a conbination for 920Ohm?
pbj:
You should be able to get 680 ohm resistors... they’re very common.
Twist legs of two of them together and then put a third in series... 1,020 ohms which is likely close enough.
Or find some 68 ohm resistors, again very common, put 3 in series and then add a 680 ohm in series.. 884 ohms or, again, close enough.
Get some resistors and a multimeter and play around, man.  You can figure this out.
PL1:
--- Quote from: abispac on April 07, 2020, 05:14:20 pm ---Ima have to wait on this one, as i cant find any 910 oms resistors locally.
That's not a very common value -- found in 5% or better tolerance resistors.
- 5%, 2%, and 1% tolerance values.  http://www.rfcafe.com/references/electrical/resistor-values.htm
- 20% and 10% tolerance values. https://www.engineeringtoolbox.com/resistors-standard-values-d_1659.html
--- Quote from: abispac on April 07, 2020, 11:29:20 pm ---
I thought they were supposed to be 910 ohms -- 920 ohms is a non-standard value.
A 430 ohm and a 470 ohm resistor in series add up to to 900 ohms.   ;D
If you don't have the right value resistors to add up in series, there are handy parallel resistor diagrams, formulas, and calculator at https://www.engineeringtoolbox.com/resistance-serial-parallel-connections-d_1881.html.
EDIT: Not sure what the max % tolerance is for the resistors in your mod.  Most common resistors are 20% or 10%.
abispac:
is this the correct way to add 1k pots to the mod? green is ground,white its out, blue with 500ohm resistor is in.
Go to full version
