Main > Monitor/Video Forum
kortek ki-2-vo brand chassis repair help - only high voltage
yotsuya:
You don’t have any sparks by the flyback, do you?
perjmolsen:
--- Quote from: yotsuya on January 08, 2020, 03:10:53 pm ---You don’t have any sparks by the flyback, do you?
No, no sparks
perjmolsen:
Hi
Just an update -
The Fly is model KFS-60291, I have orderd a new replacment HR 8508 today, lets see if that brings back life
I will keep you updated :)
princess prin prin:
If high voltage comes and then goes it can be the x-ray protection that shuts down the horizontal drive. Lift one side of D541 near the HA11235 and see if you get a picture. If you do, switch the monitor off quickly. The x-ray adjustment pot is broken so it may be sending a voltage high enough to trigger the protection.
perjmolsen:
--- Quote from: princess prin prin on January 09, 2020, 04:59:07 am ---If high voltage comes and then goes it can be the x-ray protection that shuts down the horizontal drive. Lift one side of D541 near the HA11235 and see if you get a picture. If you do, switch the monitor off quickly. The x-ray adjustment pot is broken so it may be sending a voltage high enough to trigger the protection.
Super I did not know that :notworthy:
I will try to test :D and keep you updated
