Main > Monitor/Video Forum
kortek ki-2-vo brand chassis repair help - only high voltage
perjmolsen:
Hi
I have now pulled out every component in the x-ray circuit, all components test as they are specified.
Also pulled out the HOT (D1399) according to the datasheet is has a damperdiode build in, it also tests OK
:hissy: :notworthy:
princess prin prin:
You're not using the original tube are you? The inductance of the horizontal coil may not match the value required by the chassis.
perjmolsen:
--- Quote from: princess prin prin on January 13, 2020, 03:10:37 am ---You're not using the original tube are you? The inductance of the horizontal coil may not match the value required by the chassis.
Hi
I think that is is the original monitor, but I will check later today.
I got three monitors and chassis for free, the seller had marked them so that the chassis and monitor where paired.
