Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Crt emudrivers adrenalin update needed  (Read 1910 times)
xbrunox
  • Last login:Today at 03:44:01 pm
« on: January 07, 2020, 04:59:05 pm »
Hi Calamity,
I've a small request... Not so small really...
Pls can U release a New version of Crt emudrivers
Based on adrenalin 19.12.2 or later Pls...
Unfortunaly previous adrenalin version have very big problems with supermodel emulator (Ian the authors has speak with AMD drivers team too) and the older Crimson version Unfortunaly don't support vulkan that Unfortunaly is necessary for the latest Cxbx version..
rancid
  • Last login:February 16, 2020, 09:23:40 am
Re: Crt emudrivers adrenalin update needed
« Reply #1 on: January 07, 2020, 08:07:27 pm »
From what I understand it is a tremendous amount of work to update these driver sets which is why it doesn't happen often.  I would be willing to contribute towards funding Calamity's time for a new update as well just to get better vulkan support.
  • Last login:Today at 06:46:50 am
« Reply #2 on: January 08, 2020, 04:03:56 am »
As said it's a lot of work. I'd like to release a version per year at least. I'm currently working on an update of Switchres which has been postponed for too long. I won't be able to focus on CRT Emudriver for some months.
It's a shame about AMD drivers.
 - Attach resulting romname.txt file to your post, instead or pasting it.
BahnYuki
  • Last login:January 09, 2020, 12:07:20 am
« Reply #3 on: January 08, 2020, 06:28:32 pm »
What I've done is downloaded the exact driver that is patched, for instance for my R7 250 I use the 18.5.1 driver and install that first. Then I install the CRT EmuDriver afterwards. I know have Vulkan usuable as well as the features from CRT EMudriver like VMM functional.
rancid
« Reply #4 on: January 17, 2020, 10:37:23 pm »
Interesting, do you mind helping me with a r380x?  Are you saying download an official adrenaline set that works with my card, install the package and then emudriver on top?  I'll give it a shot if that's all that is to it.
« Last Edit: January 17, 2020, 10:42:46 pm by rancid »
psakhis
  • Last login:Today at 05:35:30 pm
« Reply #5 on: January 18, 2020, 03:36:38 am »
You can try downloading vulkan sdk...
https://vulkan.lunarg.com/sdk/home#windows
alex2005
  • Last login:Yesterday at 09:51:42 am
« Reply #6 on: January 18, 2020, 01:28:00 pm »
Whats the issue with supermodel emulator?
Just out of curiosity. In my setup sega rally 2 has some graphic flaws but always thought its an emulator issue, not a drivers issue.
Could anyone elaborate a bit please?
Thank you
Foxhole
  • Last login:Today at 04:41:16 pm
« Reply #7 on: January 18, 2020, 01:58:39 pm »
Supermodel works very slow on the adrenalin drivers, on win7 x64, unless you use the legacy engine. Not sure about win10 compatibility.
xbrunox
« Reply #8 on: January 18, 2020, 03:30:14 pm »
https://community.amd.com/thread/242361
psakhis
« Reply #9 on: February 23, 2020, 05:09:03 pm »
I have similar problem with cemu, in my case testing 1.7.2b version with major vulkan improvements.
The vulkan driver 18.5.1 outdated makes visual glitches. I find this workaround with perfect results now.
 1-Download latest drivers
 2-Expand vulkan files, in my case: amdvlk32.dl_, amdvlk64.dl_, vulkan32.dl_, vulkan64.dl_, vulkaninfo32.ex_, vulkaninfo64.ex_
 3-Replacing files of system32 and syswow64.
     3.1) amdvlk32.dll and amdvlk64.dll
     3.2) amd-vulkan32.json, amd-vulkan64.json
     3.3) renaming vulkan32.dll to vulkan-1.dll, vulkan64.dll to vulkan-1.dll, vulkaninfo64.exe vulkaninfo.exe
I don't know if this method is avaible with opengl... :dunno
psakhis
« Reply #10 on: February 24, 2020, 02:23:19 pm »
Hi! I do the same method for OpenGL. In my case i don't notice better performance in supermodel emulator, maybe my GPU isn't so good (ATI 7750).
Yuhuuu i tested rev729 and its 60fps perfect! Maybe latest wip it's the problem  ::)  (*)
These files for replace on system32 and syswow64:
atig6pxx.dll
atig6txx.dll
atiglpxx.dll
atio6axx.dll
(*) Seems superior wip revisions from 729 lose performance...at least with my gpu.
« Last Edit: February 24, 2020, 03:34:14 pm by psakhis »
faxesystem
  • Last login:September 14, 2020, 04:02:46 am
« Reply #11 on: August 27, 2020, 03:06:36 am »
Sorry for digging this up. I tried to update the Vulkan drivers as suggested but sadly it's not working for me.
I have the same graphical glitches with CRTEmudriver in CEmu. I did as psakhis wrote and replaced the Vulkan files from the latest drivers with the one in SysWOW64 and System32. CEmu now crashes, Dolphin says it can't load the Vulkan drivers and Retroarch is also crashing. So is there anything else in order to get the Vulkan drivers updated?
Thank you for your help.
I got it working but have to do some further tests. If I can confirm this solution it will be a bit easier than the one mentioned already in here.
« Last Edit: August 27, 2020, 08:19:14 am by faxesystem »
Yuke
  • Last login:December 18, 2020, 07:05:20 pm
« Reply #12 on: December 18, 2020, 06:21:30 pm »
Any news on this, mate?
