Software Support > GroovyMAME
Crt emudrivers adrenalin update needed
shiryu55:
I am not clear about the new process to have the latest crt drivers with vulkan,,
It would be something like this .
uninstall drivers 18.5.1 and crt emudriver.
install the version you posted on driver https://drive.google.com/file/d/1fZ6CB8rSCdxEohYmIDPTxYc40LGx3bh7/view
And then do you have to carry out some other process?
psakhis:
--- Quote from: shiryu55 on April 17, 2023, 01:22:30 pm ---
It's all. It's the same @Calamity driver, i only added vulkan files on it.
Dalba:
Hello psakhis,
Since i updated my win10 with latest windows updates and all emulators to latest, i'm not able to use anymore vulkan driver in emulators (Pcsx2, retroarch flycast and parallei) with my HD7850. I tried to reinstall your driver but it's still the same...
Do you have an idea what could do the trick ? Until i did those updates, your driver was working perfectly for vulkan...
Milsancho:
--- Quote from: psakhis on April 17, 2023, 01:58:23 pm ---
I also want say hello and thanks to psakis. But since the thread is a bit confusing if you read it from the beginning, let me ask again if, for a new installation with Windows 7 64 bits, do I just need to install this:
https://drive.google.com/file/d/1gJ0yGqqv54foLcAzxiAhBVpCcizyrIBC/view?usp=share_link
instead of the official CRT Emu Driver or any official AMD driver previously, as mentioned very earlier in this thread?
Is there any drawback against installing the official Emu Driver? If there isn't, why Calamity hasn't made of it the official version as he proposed here?
Dalba:
--- Quote from: Dalba on October 15, 2023, 06:35:05 am ---Hello psakhis,
I reply to myself as i may have found a clue about what is happening. Problem come from updating my emulators. Regarding Pcsx2, since version 4886, it seems they use newer functions in vulkan than before. In log this is what i found : "Vulkan: Missing required extension VK_KHR_push_descriptor. Failed to create GS device".
Pcsx2 versions older than 4886 work OK.
I guess it's the same thing with newer cores of flycast and parallei in retroarch.
Psakhis, is there a way to update vulkan version included in your modded driver to meet new requirements ?
Navigation
[0] Message Index
[*] Previous page
Go to full version
