Main > Driving & Racing Cabinets
Link play on San Francisco Rush & all vegas/seattle games
<< < (23/29) > >>
Super-Becker:
PC1: Ryzen 5 5600X - 32 GB DDR4 RAM - RTX 2060 SUPER (GALAX)
PC2: Ryzen 5 5600G - 32 GB DDR4 RAM - GTX 1660 SUPER (GALAX)
MAME 60fps 500mhz version of Bigtymer781.
I uninstalled the TAP files and did a new installation:
1 - I installed "OpenVPN-2.6.9-I001-amd64" (other versions didn't work including the latest 2.6.10). I restarted the PCs.
https://openvpn.net/community-downloads/
2 - I installed "tap-windows-9.24.7-I601-Win10". I restarted the PCs.
https://build.openvpn.net/downloads/releases/
Everything is working perfectly. There are no disconnections and the oscillations of the cars are almost zero. I hope it works out for you too. I'm grateful to everyone! Thank you very much!
EDIT: Obviously the fact that I changed my Core i5 to a Ryzen 5 (PC2) was essential, but even so there were constant disconnections.
jorgenjl2:
--- Quote from: Super-Becker on May 19, 2024, 09:32:58 pm ---
Holy crap you did it. A straight run through of all tracks with no disconnects!
What do you mean by your edit? The YouTube video showed no disconnects. Do you think the key is the 60fps 500mhz update or the vpn or the pc? What version of Mame is the 60fps running in your YouTube video and where did you get the 60fps mod?
Super-Becker:
My "edit" was just to make it clear that the fact that I replaced my Core i5 16GB RAM DDR 4 with a Ryzen 5 5600G 32GB RAM DDR 4 (PC2) was not enough to avoid disconnections. Only after doing step 1 and 2, I managed to get the result shown in the video. I'm looking forward to seeing the results of someone who does the same.
Super-Becker:
--- Quote from: Bigtymer781 on January 18, 2022, 05:57:01 am ---Here are the MAME 0.239 (60fps) versions, they use the slider hack also.
There's 3 versions, each one is a little more demanding on your hardware with slightly higher overall FPS. If your emulation speed is dropping below 100%, I wouldn't even waste time downloading a more demanding one because your FPS will usually drop when the emulation speed drops.
Main CPU R5000 @300mhz and Voodoo 1 slightly overclocked
https://drive.google.com/file/d/1Hg1zQF7ZBZ5RE2Q1azfmEeQuyb1lRfFG/view?usp=sharing
Main CPU R5000 @400mhz and Voodoo 1 slightly overclocked
https://drive.google.com/file/d/1RimUGCbuHm5qW_4QfFYusqcU4fucC2gr/view?usp=sharing
Main CPU R5000 @500mhz / Main CPU RM7000 @350mhz with Voodoo 1 AND Voodoo3 slightly overclocked (for Rush 2049)
https://drive.google.com/file/d/15KWnfNTya5AGtzbeGPrdzjIgNYdog29i/view?usp=sharing
The sound glitch for the race countdown voice still happens. I don't think overclocking causes the problem, because it only happens once the FPS is boosted in the slider menu. I think it could only be fixed by hacking the rom, since it seems reliant on the frame rate.
Here are the 60fps versions made available by Bigtymer781.
I believe that the result is due to the performance of the processors and the correct versions of the VPNs. I don't know if MAME 60fps 500mhz helped because I didn't test it with any other version. As this is the version that demands the most from processors, I believe it works well with other versions as well.
jorgenjl2:
--- Quote from: Super-Becker on May 25, 2024, 05:56:17 pm ---My "edit" was just to make it clear that the fact that I replaced my Core i5 16GB RAM DDR 4 with a Ryzen 5 5600G 32GB RAM DDR 4 (PC2) was not enough to avoid disconnections. Only after doing step 1 and 2, I managed to get the result shown in the video. I'm looking forward to seeing the results of someone who does the same.
Oh that may actually be good news as I was hoping my three 4th gen i7s (and one amd 3600) would work without upgrading. I will try using the non 60fps regular Mame version with those versions of the openvpn and tap adapter. I had gpt4o create a script for the enabling of the tapvpn bridge properties where most of it is all regular programmatic powershell commands but the click of the “properties” will depend on your resolution so that one piece will have to be edited for different resolutions since it uses auto hotkey to “click” on a specific section of the screen (but is programmed). Then we could programmatically remove that to go back to other games besides SF Rush/The Rock/Rush 2049/California Speed
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
