Main > Driving & Racing Cabinets
Teknoparrot runs H2 Overdrive
<< < (6/6)
lancelotedaninho:
--- Quote from: Boomslang on May 07, 2021, 05:10:38 am ---Bumping this topic
H2Overdrive network should now work for everyone (after updating Teknoparrot)
- All ips must be on the same network prefix x.x.x
- Enter into TPUI just the final segment of your ip eg 192.168.1.2 you would just enter 2 for that machine
- Modify Cabinet ID in test menu if you want it to show correct cab id upon startup
- Huge thanks to Spazzy for helping on this
How did get that to work?
Im using two PCs directly connected with static IP, 192.168.0.1 and 192.168.0.2. I use those IP in teknoparrot, modify in test menu 1 and 2 for each PC and still dont work in LAN. Theres one one version of the game or Im doing something wrong ? Almost other LAN games on TP work for me
Boomslang:
what are you entering into TPUI?
PC1 should just have "1" and PC2 should have "2" on both computers in TeknoParrotUI
lancelotedaninho:
--- Quote from: Boomslang on February 06, 2022, 04:17:07 am ---what are you entering into TPUI?
Thanks, it works now !!! I was using my IPs for each PC 192.168.0.1 and 192.168.0.2  :P
Navigation
[0] Message Index
[*] Previous page
Go to full version
