Main > Monitor/Video Forum
Hantarex Polo B+ 164V with flyback connected.. (SOLVED)
grantspain:
maybe a bad crt socket, did you get the focus and screen volts wires in the correct place
perjmolsen:
Just to finish this also :)
The chassis is fixed!
1. The high B+ with fly connected, a bad TH102
2. the shaky/blurry image when i turned on -> solution, just turn the screen volt down on the fly. :laugh2: :banghead:
Then adjust the pot so the image fitted the screen.
:applaud: :applaud: :notworthy:
perjmolsen:
Hi
Just to finish this up
I had an extra look at the broken TH102 - it where just the one wire on the coil who where corroded.
Fixed it with some wire from a small resistor, now I have a workin TH102 coil :applaud: :applaud: :cheers:
