Main > Monitor/Video Forum
Hantarex Polo 25 ticking with neck glow
perjmolsen:
Hi
I also have had an issue with high b+ due to a bad solder connection in the PSU part.
I fixed it by re solder all the components in the PSU selection, then my B+ where back to normal.
As I recall it where the two big resistors in the psu part where one of them had a bad/cold connection to the PCB and it where really hard to see.
retrocat:
thanks. i'll try to reflow the solder and see how it goes.
i got another chassis that is doing the same thing when connected to this tube (the neck flashing in the video in the first post). does this indicate a tube problem? is there a way i can test the tube to know its ok?
grantspain:
tube has gone to air, in other words its knackered
