Main > Monitor/Video Forum
Hantarex Polo/2 25-28 Dead - how to test B+ (SOLVED)
grantspain:
hr7191 is required
perjmolsen:
--- Quote from: grantspain on January 17, 2020, 06:04:49 pm ---hr7191 is required
Ok thanks :cheers:
I just tried another HR7191, the same issue, so ruled out the flyback.
Thinking the next step is to change the last electrolytic caps...it might be a bad cap, and its an easy fix if it is, and it may need a cap kit anyway
grantspain:
or you need to adjust the horizontal hold pot or horizontal shitft
perjmolsen:
--- Quote from: grantspain on January 17, 2020, 07:15:08 pm ---or you need to adjust the horizontal hold pot or horizontal shitft
Tried to adjust the pots, I am unable to get the picture better.
I noticed that the H.AMP and KEYSTONE does nothing at all...
grantspain:
look at all the diodes in the horizontal circuit
