Main > Monitor/Video Forum
Hantarex Polo/2 25-28 Dead - how to test B+ (SOLVED)
Pages: << < (3/9) > >>
grantspain:
you should check the poly hv caps
grantspain:
also put the track back how it was for the time being- i will check one of my chassis tomorrow to see if it has the same mod
perjmolsen:
Hi
I have tested all the poly caps around the fly - they tested OK - even also replaced them with some new, but still B+ is 185-190V
I have removed the jumper at the track :)
grantspain:
you replaced the flyback?
perjmolsen:
Yes I have tried to put the original flyback back (HR7191), but still the same issue, stil high B+
So it is not the flyback...
Go to full version
