Author Topic: Possible solution: one button to shut down question  (Read 957 times)
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« on: February 16, 2004, 12:32:21 am »
Thanks to prior threads on this I was able to get 98 to shutdown with one press of button.  Now, working on my second cab computer, its an older Dell 400, I am certain it is a momentary button.   Runs Win98SE.  when I press the button it shuts off immediately, does not seem to go through windows shut down process like when I use the start button to shut down.  But, weird thing its when I start up again, I do not get an error message stating windows was shut down improperly and if I want to scan disk the hard drive.
Any suggestions?  Or is it okay?
Thanks,
« Last Edit: February 17, 2004, 12:24:06 pm by bdsjake »
crashwg
Re:one button to shut down question
« Reply #1 on: February 16, 2004, 01:53:48 am »
check "power options" in your control panel, maybe there will be something there, but I haven't used 98 in like 2 years so I may be wrong on that ::)
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
« Reply #2 on: February 16, 2004, 09:48:32 am »
On my 233 mhz mame comp the bios takes over and just shuts straight down and i cant change it, so i use mamewah to shutdown on exit
eightbit
  • My cab is never done...
« Reply #3 on: February 16, 2004, 09:14:14 pm »
Check your power options in the bios, some computers support a clean shutdown others don't.
bdsjake
  • livefree
« Reply #4 on: February 16, 2004, 10:37:01 pm »
i checked both power options in bios and in control panel, couldn't get it figured out.
anyway I could program a button to send the correct keyboard commands to do a proper windows soft shut down (and what would they be)?
I note newest hagstrom encoder allow you to send a string of keyboard commands with one button press.
thanks,
bdsjake
  • livefree
Re:Possible solution: one button to shut down question
« Reply #5 on: February 17, 2004, 12:26:26 pm »
Do any of you Windows 98 gurus know if it would be possible to program a button to send the proper soft shutdown command?
For example, If the buttun could send CTRL-ALT-DEL, then ALT-S, that would seem to do it.  I note Hagstrom encoders says it can send a string or macro of commands.
or, is there a keyboard command to open the "start" button, you could then use arrow keys and enter to shutdown.
thanks,
drunkatuw
  • Last login:April 24, 2024, 09:17:42 am
    • Drunk at UW.com
« Reply #6 on: February 17, 2004, 12:32:23 pm »
Ctrl+Esc, u, s will shut down a computer from the start menu.
bdsjake
  • livefree
« Reply #7 on: February 17, 2004, 04:12:15 pm »
ah, thanks, I new someone here would help!
eightbit
« Reply #8 on: February 17, 2004, 09:58:25 pm »
Check your front end for options to shut down the computer. Mamewah has the option to do this.
