Main > Lightguns
GUN4IR - The Ultimate 4 Points Lightgun System
<< < (190/227) > >>
Headrush69:
--- Quote from: JayBee on December 12, 2021, 06:27:41 am ---
--- Quote from: agent_c on December 12, 2021, 05:59:42 am ---Has anyone converted the gun con 2's by using samco's replacement board and then using Jaybee's 4 point ir/software? I just managed to get two gun con 2 guns for £10 and would like the simplicity of putting in the board from Samco as it will be easier and better internally with the arduino mounted and all the wiring neat and tidy, I was going to use a "the real arcade" jolt gun (another £10 buy) to convert but the gun con2 looks like a better option to me, especially as I will have two of them.
The Samco board pinout and mine are different, it won't work.
But I'll sell drop in kits soon for the gcon1/2 if you are interested.
I have done this. Obviously you can't use the pin header but you can wire them up appropriately. There was plenty of room in the Guncon 2s for this. In my case the original guncon 2 board was in rough shape and this was the easiest, fastest solution for me.
agent_c:
What are the drop in kits Jay? Cost etc.
agent_c:
--- Quote from: Headrush69 on December 27, 2021, 06:05:33 am ---
Ithought the same, just wire direct and it will work, like you i think the original g con board is just too complicated to leave in and the samco board answers the tidiness and space for stuff, thanks for the reply.
tarnfeather:
--- Quote from: woordmand on December 20, 2021, 10:03:19 am ---
--- Quote from: holmes on December 19, 2021, 12:07:21 pm ---
--- Quote from: woordmand on November 13, 2021, 03:26:39 am ---I found the smallest second-hand IR sensing part, and the test was successful. The assembly has been completed.
Could you give a link or directions to find this?
I bought the electronic components and spent some hours trying to solder the leds. I ended up with a very unreliable device.  :-[
This is a camera from China. Its price is not high, but the freight is too high. Can only find friends to buy together and share the freight. You need  infrared LEDs, 3 LEDs and a resistor in series. I use a 25 Ω resistor, which smaller.
Could you still provide us with the part number or a link to where you ordered it?
woordmand:
--- Quote from: tarnfeather on December 28, 2021, 12:49:51 pm ---
I can't find the model number. It's second-hand. You have to consider long distances and shipping costs. And slow transportation.
https://market.m.taobao.com/app/idleFish-F2e/widle-taobao-rax/page-detail?wh_weex=true&wx_navbar_transparent=true&id=661132861950&ut_sk=1.WylAcgYoPT8DAAiWBjStYn5A_21407387_1640879555623.copy.detail.661132861950.16753707&forceFlush=1
Navigation
Message Index
Next page
Previous page
Go to full version
