Main > Monitor/Video Forum
NeoTec NT-27E (San Francisco Rush) Need Help
Pages: << < (2/2)
grantspain:
so you proved the neck card and tube so issue must be on main chassis
check values of R429,R430, R524 and R526
grifter2:
Great, thanks, i am heading home from work now and will report back soon.
grifter2:
--- Quote from: grantspain on September 13, 2019, 02:19:02 pm ---so you proved the neck card and tube so issue must be on main chassis
GRANTSPAIN you are my new HERO!!!!!
R526 was the ticket, pulled it out, showed 0 ohms, replaced with a new 1/2 watt 2.2 ohm resistor and the monitor works perfectly now!
I never even got to R429, its under the flyback so i figured i would try the easy 3 first.  R430 and R524 tested ok when compared to the values in the manual.
Thanks everyone for your help. the monitor lives again!!!!
grantspain:
excellent, what about some photos of the game running
grifter2:
Pictures or it never happened :-)
Works great. Got the monitor back in last night and raced my wife for a while. Never got the whole unit together. To distracted now that they both work. :-)
It did have one other problem with a bad solder joint on the neck board that would cause blue to drop every once and a while. Found that pretty quick and fixed it with a short jumper wire.
Sorry posting these from my phone while waiting for my plane to take off and I cant figure out why my phone shows them rotated properly but the forum flips them.
Thanks again for your help!
Pages: << < (2/2)
Go to full version
