Main > Main Forum
Golden tee stop working
Encryptedmind:
Thanks. I have a 2018 hard drive brand new. not been upgraded. The golden tee was originally 2009 that was upgraded to 2015 then the new hard drive in 2018. I never replaced anything else. So can i use any of the boards listed? I also have a Zotac 740 GT 2Gb video card and one gig ram installed.
This is the board i bought from ebay ~INTEL D915GUX, AA C63985-202 LGA 775 Motherboard +CPU Intel Pentium 4 540 3.2gh. Was that the right board to buy?
lilshawn:
the board model you got looks correct. the cpu doesn't particularly matter as long as it's "socket compatible". (IE socket 775)
yes, with 2018 you should be able to use any of the listed boards. they more or less just change boards when the current model supply dries up... they would just add driver support for the new board into the next years game release.
so the latest version will have support for the current and all previous boards used.
JudgeRob:
Did you try a new psu yet? I don't know anything about your machine but I did have a PC once that would almost boot up and fail. I never suspected the psu because ot seemed to be getting power. After troubleshooting the bios and everything else, I rolled the dice on a psu and it turned out to be the culprit.
lilshawn:
he did mention in one of the first posts he'd replaced the power supply.
never know...maybe the PSU STB :dunno seen weirder things happen.
Encryptedmind:
Question if i take the motherboard out and try to power it up by itself with ram and a video card installed on it will it post? Or does it have to be plugged into all of the other boards in the golden tee machine. Does the IO board have anything to do with it not posting? Just seems strange that both motherboards are kaput.
