Main > Main Forum
Golden tee stop working
Pages: << < (3/10) > >>
lilshawn:
do you have another videocard you can try? it needn't be exactly the same since it's just for testing purposes only.
make sure that videocard is seated all the way down. sometimes the tab at the locking tail end there can cause the board to look like it's in, but the but end is sticking out.
don't try to use the on motherboard board VGA connector...the CPU's are low budget SKU's used in these machines, and they don't have video built in. it won't work.
Encryptedmind:
So i pulled out the video card and tested it in my PC and it works fine. So what is stopping it from working when plugged into my golden tee cabinet. Does the jumper have anything to do with it? Or the battery. Any idea lilshawn?
lilshawn:
okay, so we have eliminated the videocard as your source of issue. what about the CPU? did you purchase a replacement board without a CPU, then transferred the CPU out of the dead board into the new board?
I ask, becasue often if a board goes kaput, it often takes out the CPU and/or RAM modules.
Encryptedmind:
I got a complete used board didnt swap anything over except for video card and ram.  Ram is good i tried that in my computer also. Is this motherboard junk too? I just want my golden tee back.
Thanks again lilshawn.
Encryptedmind:
Is there anyway to test the HDD if thats good or not? Can i boot it up in my pc or no?
Go to full version
