Main > Monitor/Video Forum
Hantarex MTC 9000 image squashed vertically
Pages: << < (10/10)
grantspain:
if the hiss is neck card then i expect its the really old crt socket and they corrode internally, if its the anode then it could be slightly damp and will clear in some time or with a gentle clean, or there is corrosion on the connection of the anode clip to cable
lin coil you can manipulate the coil wire fractionally or reseal with a lacquer
be77amyX:
I'll check out the anode cap tonight. Is there anywhere that still sells the neck sockets? How would I go about resealing the coil? Also is there anywhere that sells replacements for them that your aware of?
grantspain:
quick fix for the coil is tape a wooden toothpick to it
what crt socket type is it?
be77amyX:
Here's a picture of the CRT socket
grantspain:
rare to get issues on that type socket
Pages: << < (10/10)
Go to full version
