Main > Monitor/Video Forum
27" WG2572 Monitor requires Isolation Transformer?
grantspain:
https://www.wellsgardner.com/wp-content/uploads/2016/08/U5000_25.pdf
Lukey13:
Awesome, I saw that manual online before but completely missed that it was also for the 27" and my part number is in there so yep, pretty much confirms 27" U5000 for me.
Thanks guys!
Although it states no Isolation transformer required, would any of you recommend installing one for added protection to both me and my jamma PCB's themselves?
lilshawn:
that's the best part about a switch mode supply. you can plug it into just about any voltage and it will adjust it's pulse width switching of the output MOSFET to match the output it's expecting. so on 100v...it will be more "on" than "off" whereas at 240v, it would be more "off" than "on" not needing as much to get the same output.
