Main > Monitor/Video Forum
pico 110° 15/25 khz ,can't adjust it
shingo yabuki:
Thank you so much brother, I will check the pieces and come back
shingo yabuki:
Hi princess prin prin
I delayed because it's almost my first experience in electronics
testing results:
T106 = good
T107 = bad
D 136 = good
IC105 = 24,5 v in pin 6 (I think the value is correct)
I ordered the t 107 and the ic 105 , Once the request arrives I inform you about the results
thanks a lot
shingo yabuki:
Finally the package has arrived , after replacing T107 and ic 105 the problem persists without any noticeable improvement
What do you suggest?
I'm stuck again please help
