Chained in series or Parallel with a connection for each one?
Daisy-chained in parallel with 0.250" QDs. One daisy-chain for ground (black), the other for operating voltage. (red)
Several vendors like
GGG and
Paradise sell pre-fab harnesses.
My PSU has 2A on the 12V rail, I want to light all 10 buttons and possibly 2 led strips for the marquee, will there be enough current for all the bulbs and the gameboard?
10 LED single-color buttons * 20mA per LED = 200mA -- no problem.
Can't say for sure how much the LED strips will draw without knowing the specs and how many LEDs, but you can get close with these estimates.
- Single-color LED strips: #LEDs * 20mA
- RGB LED strips: #LEDs * 60mA
- These strips are likely to need a separate power supply.
I could use those newer LED capless wedge bulbs rather than the older type.
If by "older type", you're referring to incandescent bulbs, those draw about 500mA each IIRC -- too much current, too much heat,
do not use for your setup.
The default choice is a normal (non-surface mount) LED in a wedge-base socket like
this one. It is the type of LED that usually comes with that type of button.
The other option that you may have seen is a wedge-base surface-mount LED like
this one. They have a slightly larger outer diameter that
usually doesn't fit in rectangular buttons, but should work in your round buttons. These "superbright" LEDs may draw more than 20mA.
