Main > Main Forum
Help! Game Board Repair (Super Pang)
Pages: << < (4/8) > >>
CHRIS-F:
It looks like my victory was short lived :-((
My youngest son was playing it for a while and the sound went funny, most of the sound works but it sounds at though one of the channels has gone down, and when I tried it again today its making some noises when starting up that shouldn't be there and failed to boot again, I just don't know where to look for an intermittent fault like that.
could the missing sound problem be the LM324A maybe? if so where can I get a replacement? can I trust the ones on ebay? also could it have something to do with the M5205 again can I trust the ones on ebay manufactured in Thailand? could it even be the YM2413?
I'm sorry I bought the board now it must have been cheap for a reason, my problem is the board is not even worth the hourly rate for someone who knows what their doing to look at it, I don't really have a clue :-(
If those few chips are not to be trusted from ebay, where can I find alternatives in the uk?
Thanks,
Chris.
opt2not:
You could start by replacing the caps in the audio circuit.  They're usually all clustered together.  By the looks of your previous picture, the top-left section looks to be the audio area.
Given that this is a bootleg, there aren't going to be any hard to obtain custom IC's you need to worry about. So I would just try to rebuild the audio circuit, simple components at a time.
yotsuya:
Try the sound amp chip. I’ve replaced two of those on different boards and that solved sound issues
Mike A:
That fixed my vanguard board.
CHRIS-F:
--- Quote from: yotsuya on June 24, 2019, 06:35:28 pm ---Try the sound amp chip. I’ve replaced two of those on different boards and that solved sound issues
Which one is the sound Amp? the LM324A or do you mean the actual amplifier which looks like a Voltage regulator TDA something or other? I was thinking the LM324A as it's a quad op amp and that would make sense if it's amplifying 4 separate channels and one has gone down, but if the TDA amp has died there wouldn't be any sound would there?
Thanks,
Chris.
Go to full version
