Main > Monitor/Video Forum
hantarex polo 28 blows fuse
Pages: << < (8/10) > >>
perjmolsen:
Well... got the new resistors today, and put them in.. still the same issue.  :badmood: :banghead:
Pin 1 and 3 is disconnected at the flyback, 40W load on pin3 pad and chassis as ground.
A smalll video -
 :dizzy:
grantspain:
remember to bridge the centre two pins of deflection header or have the yoke plugged in
perjmolsen:
Hi Grant  :cheers:
Yes - I have Remember to plug in the yoke plugged in.. even that i wish i not had at the moment, so it had been an easy fix  ;D
I have tried to measure between chassis ground at the test points...
TP6= 100.3 Ohm
TP7= 0 Ohm
TP8 0.794 Ohm
TP9= 33.23 Ohm
Can there be some sort of small short when i get a ohms reading?
Thinking that I might have to take some measurements on my other Hantarex chassis.. it should have the same ohms readings
perjmolsen:
Hi  :cheers:
Some updates
Took som measurements on my other working chassis
TP6= 0.750 ohm (took awhile before it where steady- on my bad one is immediately go to 101.3 ohm)
TP7= OL
TP8= 0.928 ohm
TP9= 191.9 ohm
Noticed a burned spot on my bad chassis.. but i have measured the diode and resistors on it, they measures ok - but thinking that i might need to change the parts, because on my working one no burned spot
still a bit  :dizzy:
perjmolsen:
Tested ohms across the resistors in the burned circuit at the bad chassis,and got these values (tested in circuit)
R119= 001.4 ohm
R255= 003.1 ohm
L112= 003.1 ohm (colis)
L102= 001.6 ohm (coils)
R118=0.920 ohm
Same measurements taken on my working chassis resistors in circuit
R119=000.4 ohm
R255=000.9 ohm
L112=000.6 ohm (coils)
L102=000.3 ohm (coils)
R118=0.953 ohm
So next step is to pull the resistors out in the bad chassis and test/replace them.
If I look at the colors I get this values, sometimes my eyes cant see colors, so can someone confirm the values?
R119= 100 ohms
R255= 560 ohms
L112=220 ohms (coils)
L102=150 ohms (coils)
R118= 1k omhs
If I pull the resistors out i get this reading:
R119= 97.4 ohms
R255=0.548k ohms
L112= 4.4 ohms (coils)
L102= 2.6 ohms (coils)
R118= 0.989k ohms
So my conclusion is that L112 and L102 is coils and cannot be tested this way, all the other comments are close to spec and not the cause
Go to full version
