Would it work to outline the monitor with EL tape instead? IR LED strips all the way around would be more ideal, but i imagine that would require major changes.
Someone is testing that atm I believe.
The gun just needs to see a clear border it does not really matter ehat the border is so you could probably put tape around your monitor or something.
The issue is when you go to change aspect ratio because the border needs to mate the aspect ratio.
Long term I think the solution will be to basically window the game inside the border.
Some emus can do this allready no problem others cant.
The Tekno Parrot devs are fully behind the project and are currently working to incorporate the sinden into all the lightgun games it supports.
Howard maybe you could get involved and help with the windowing idea if it bothers you that much?
I told you guys way back at the start this was a really good workable solution but Andy has been going it alone for however long.
The amount of support its gained the last month has been amazing (just check the backers of it!)
He did what he promised now hopefully the community can perfect the solution.
