Author Topic: Sega Model 2 UI  (Read 80557 times)
Nuexzz
Sega Model 2 UI
« on: March 04, 2019, 11:06:06 pm »
Hello everyone, it really bothers me to have to do many steps to configure my favorite game, then I started to add some features for Daytona and started adding functions until I finished adding all the games.
Keep in mind that if you have errors is because I'm not a programmer (just a curious) which I consider a Hobby, I have no trouble for the aggregates I plan to do.
in a few words, I publish it to not keep it for me, as I did with many things.
This is a simple UI for the "GREAT EMULATOR" By ElSemi SEGA Model 2 Emulator. v1.1a
http://nebula.emulatronia.com/
Sega Model 2 UI - by Nuexzz (c) 2019 Nuexzz@gmail.com
                      Features
Added - list view of all the supported games of version 1.1a of m2emulator.
Added - preview of each game (snaps).
Added - 3 buttons of the roms directories.
Added - check Antialiasing.
Added - check Bilinear.
Added - check Trilinear.
Added - check FilterTilemaps.
Added - check Wireframe.
Added - check ForceSync.
Added - check FakeGouraud.
Added - check MeshTransparency.
Added - check ForceManaged.
Added - check AutoMip.
Added - check Fullscreen (now with the shooting games the window will not be minimized when shooting in the upper corner).
Added - check Sound.
Added - check Widescreen .
Added - check Resolution (Native).
Added - check Force Feedback.
Added - check HoldGears.
Added - check Joy Xbox360 (xinput).
Added - check (Cursor) Show / Hide.
Added - check DrawCross.
Added - check UseRawInput.
Added - check RawDevP1.
Added - check RawDevP2.
Added - check Load button (Load Rom).
Priorities for future versions
Add - Widescreen (correctly) to all the missing games.
Add - support of the games that use system links, in simple steps so that everything is configured automatically "same pc", "pc in network", "online".
"Maybe" add - Model1 (MAME).
"Maybe" add - Model3 (Supermodel).
http://uploaded.net/file/ryc0vp4f
Update 02/04/19
add - new font and color in the gui
add - volume control
Add - drop-down menu in case of adding some hacks :)
add - many games with widescreen support (correct)
fix - writing code that if it was not the key it wrote ERROR
fix - the first resolution option was left blank
games with widescreen (correct) so far
daytona
dayton93
daytonas
daytonase
daytonat
daytonata
daytonagtx
daytonam
desert
doaa
pltkidsa
srallyc
srallycb
srallyp
vf2o
vf2a
vf2b
vf2
doa
fvipers
indy500d
indy500
indy500to
pltkids
sgt24h
vstrikro
vstriker
hotd
skisuprg
« Last Edit: April 03, 2019, 04:25:35 am by Nuexzz »
isamu
  • Last login:March 18, 2024, 02:38:32 am
Re: Sega Model 2 UI
« Reply #1 on: March 05, 2019, 10:16:16 pm »
Cool!  :cheers:
baritonomarchetto
  • Last login:Yesterday at 02:11:31 am
Re: Sega Model 2 UI
« Reply #2 on: March 06, 2019, 12:31:12 am »
Thanks for sharing. We are now waiting for a supermodel GUI ;)
tomato123
  • Last login:July 01, 2019, 02:38:57 pm
Re: Sega Model 2 UI
« Reply #3 on: March 12, 2019, 10:39:07 am »
Thanks! My friend!  Can you add a feature to adjust the volume to preset level, and then restore the volume after the game?
Nuexzz
Re: Sega Model 2 UI
« Reply #4 on: March 12, 2019, 07:46:47 pm »
if now that I think that is a good function to add, since I am looking for the wide screen hacks of the games and I have to reduce the volume from windows.
added (you can try it and tell me if everything works correctly then I will update to the first post )
 thanks :applaud:
« Last Edit: April 01, 2019, 09:34:11 pm by Nuexzz »
Nuexzz
Re: Sega Model 2 UI
« Reply #5 on: March 12, 2019, 09:59:25 pm »
Add - Widescreen (correctly) Dead or Alive (Model 2B)
Add - Widescreen (correctly) Dead or Alive (Model 2A)
require("model2")
function Init()
end
function Frame()
local gameState = I960_ReadByte(0x54F9D5)
if gameState==0x1
then
Model2_SetWideScreen(1)
Model2_SetStretchBLow(1)
Model2_SetStretchBHigh(1)
else
Model2_SetWideScreen(0)
Model2_SetStretchBLow(0)
Model2_SetStretchBHigh(0)
end
end
Add - Widescreen (correctly) Desert Tank
require("model2")
function Init()
end
function Frame()
end
« Last Edit: March 12, 2019, 10:40:58 pm by Nuexzz »
  • Last login:March 16, 2024, 05:59:16 pm
Re: Sega Model 2 UI
« Reply #6 on: March 12, 2019, 10:15:43 pm »
I've got a lot of scripts I wrote... maybe if I can ever get motivated to get ts2 out the door we can merge them into an all in one solution.  I just added some basic stuff like widescreen, scanlines ect.
Nuexzz
Re: Sega Model 2 UI
« Reply #7 on: March 12, 2019, 10:26:40 pm »
it could be .. I would also like to implement sweetfx (only for the curvature mode) because I could not configure it without the scanlines, I think it loses a lot of quality
tomato123
Re: Sega Model 2 UI
« Reply #8 on: March 13, 2019, 10:06:33 am »
I just test the program. The volume can be adjust in real time.
But the function I need is reduce the volume to a "preset" level" (For example If I can set it at 10%).  After exit, the game I played, it should "restore" to original volume level (The volume level before I run the game).
The process should be like this:
1) My current computer volume is 75% (could be any volume)
2) The program should record the current volume when double click the game
3) Before it run the game, reduce the volume to the "preset" level (For example, 10%)
4) Enjoy playing the game at 10% volume.
5) When exit the game, the volume should be restore to 75%
Sorry for asking too much! :notworthy:
 thanks :applaud:
Nuexzz
Re: Sega Model 2 UI
« Reply #9 on: March 16, 2019, 08:31:22 am »
Add - Widescreen (correctly) Indianapolis 500 (Rev A, Deluxe)
Add - Widescreen (correctly) Indianapolis 500 (Rev A, Twin, Newer rev)
Add - Widescreen (correctly) Indianapolis 500 (Rev A, Twin, Older rev)
add - new GUI style
require("model2")
function Init()
end
function Frame()
local gameState = I960_ReadByte(0x54C224)
if gameState==0x5
or gameState==0x6
then
Model2_SetStretchAHigh(1)
Model2_SetStretchALow(1)
else
Model2_SetStretchAHigh(0)
Model2_SetStretchALow(0)
end
end
Nuexzz
Re: Sega Model 2 UI
« Reply #10 on: March 16, 2019, 11:04:50 am »
Add - Widescreen (correctly)  Virtua Fighter 2
Add - Widescreen (correctly)  Virtua Fighter 2 (Rev A)
Add - Widescreen (correctly)  Virtua Fighter 2 (Rev B)
Add - Widescreen (correctly)  Virtua Fighter 2.1
require("model2")
function Init()
end
function Frame()
local gameState = I960_ReadByte(0x50002B)
if gameState==0x7
then
else
end
end
« Last Edit: March 16, 2019, 12:22:54 pm by Nuexzz »
Nuexzz
Re: Sega Model 2 UI
« Reply #11 on: March 16, 2019, 01:36:25 pm »
Add - Widescreen (correctly)  House of the Dead
require("model2")
function Init()
end
function Frame()
Romset_PatchDWord(ROMBASE,0x18610,0xa000000)--no flash screen (by_egregiousguy)
local gameState = I960_ReadByte(0x51EE14)
if gameState==0x2
then
else
end
end
Nuexzz
Re: Sega Model 2 UI
« Reply #12 on: March 16, 2019, 02:49:24 pm »
Add - Widescreen (correctly) Fighting Vipers
require("model2")
function Init()
end
function Frame()
local gameState = I960_ReadByte(0x50002A)
if gameState==0x7
then
else
end
end
Nuexzz
Re: Sega Model 2 UI
« Reply #13 on: March 17, 2019, 10:01:15 am »
some games resist  :banghead:
« Last Edit: March 17, 2019, 10:10:36 am by Nuexzz »
Zebra
Re: Sega Model 2 UI
« Reply #14 on: March 17, 2019, 07:37:53 pm »
Yeah... like that will ever happen. Unfortunately I already died from holding my breath while waiting for a Super Model GUI and I am now a ghost.
I have been thinking of trying to use macros in Windows to allow me to select and load games with a mouse click instead of using command line (which is usually enough to make me skip model 3 games altogether).
Nuexzz
Re: Sega Model 2 UI
« Reply #15 on: March 17, 2019, 08:09:28 pm »
Well yes, I was thinking about (pausing) model 2 UI and starting with model 3, a year ago I did not update my supermodel.
tell me one thing, why did I stop working model 3 UI? if you can post your supermodel.ini.
So we started
Stremon
  • Last login:November 20, 2019, 12:05:21 am
Re: Sega Model 2 UI
« Reply #16 on: March 20, 2019, 01:44:03 am »
This GUI looks great, but I get a serious virus warning for the zip file with my antivirus (Trojan:Win32/Zpevdo.b).
Is that a false positive or a real undetected threat?
Ali
  • Last login:Yesterday at 05:13:06 pm
Re: Sega Model 2 UI
« Reply #17 on: April 01, 2019, 07:18:49 pm »
I updated my DirectX 9... I cant to run fine the M2 emulator.
BUT... running the Nuexzz "Volume" GUI it ask me to d3d9.dll (no problem I have it in my system...)
But I puuting it in my dicectory...
It now ask me to "encdr.dll", encof.dll, snbar.dll... and I can't find it on my system (Windows 7 - 32bits) or on Internet!
Please, hat's the matter?
Is my DirectX 9 incomplet yet?
Best regards, Ali
« Last Edit: April 01, 2019, 07:25:16 pm by Ali »
Nuexzz
Re: Sega Model 2 UI
« Reply #18 on: April 01, 2019, 09:33:09 pm »
friend are you confused, these files are in the first post of this thread
also, tonight I think I'm going to upload some updates
« Last Edit: April 02, 2019, 02:51:34 am by Nuexzz »
Nuexzz
Re: Sega Model 2 UI
« Reply #19 on: April 02, 2019, 02:52:43 am »
updated the first post
daytona
dayton93
daytonas
daytonase
daytonat
daytonata
daytonagtx
daytonam
desert
doaa
pltkidsa
srallyc
srallycb
srallyp
vf2o
vf2a
vf2b
vf2
doa
fvipers
indy500d
indy500
indy500to
pltkids
sgt24h
vstrikro
vstriker
hotd
skisuprg
Ali
Re: Sega Model 2 UI
« Reply #20 on: April 02, 2019, 06:16:53 pm »
Now there are files in the first link!
Until yesterday "File removed copyrights violation"...
Many thanks to the update!
pmc3
  • Last login:April 10, 2021, 02:54:01 am
  • 404
Re: Sega Model 2 UI
« Reply #21 on: April 03, 2019, 03:47:09 am »
Hi and thanks for your work
But I can not download the file (connected to onedrive or not)   :dunno
Nuexzz
Re: Sega Model 2 UI
« Reply #22 on: April 03, 2019, 04:27:11 am »
thank you uploaded
Nuexzz
Re: Sega Model 2 UI
« Reply #24 on: April 03, 2019, 05:32:50 am »
They are false positives, we already made claims that they scan it in depth, but ... I guess it takes time.
lazzlo
  • Last login:July 12, 2019, 09:05:20 pm
Re: Sega Model 2 UI
« Reply #25 on: April 05, 2019, 08:22:57 pm »
Nice looking UI.
Any chance of an upload at www.zippyshare.com? I have troubles with the reCAPTCHA showing up at uploaded.
Thanks for any assistance you can provide.
hio3hir0wa
  • Last login:January 18, 2023, 12:33:10 am
Re: Sega Model 2 UI
« Reply #26 on: April 06, 2019, 05:52:58 pm »
Print.dll included in this program is copying not only the window of UI but also the screenshot of the whole screen being displayed to the clipboard.
What is this required for?
Please tell me.
Nuexzz
Re: Sega Model 2 UI
« Reply #27 on: April 06, 2019, 08:34:55 pm »
it's actually a little dirty trick, because when I started the emulator in window mode it always showed the native resolution of the emu (640x480) then.
Take this resource to show the desktop for 1 second and wait for the window to be resized in background mode from behind.
you can prove that print only works when you launch the game.
Maybe I should remove it if someone seems suspicious, I have no problems
edit:
Here I leave the print disabled, so you can see the difference
« Last Edit: January 03, 2021, 03:48:50 pm by saint »
AMG KC
  • Last login:June 29, 2022, 05:33:52 am
Re: Sega Model 2 UI
« Reply #28 on: April 23, 2019, 07:43:18 am »
edit:
Mine wont load it, says the d3d9dll is missing???
AMG KC
Re: Sega Model 2 UI
« Reply #29 on: April 23, 2019, 07:48:27 am »
edit:
Can you ever make it possible to add in networking settings into this GUI as well and the ability to turn on lagfix or other things like that?
Nuexzz
Re: Sega Model 2 UI
« Reply #30 on: April 23, 2019, 07:53:21 am »
hello, when finished with sega model 3UI I plan to add those network functions and clean a little sega model 2UI
AMG KC
Re: Sega Model 2 UI
« Reply #31 on: April 23, 2019, 07:55:19 am »
That would be great :)
Can you use a better place to upload the file? Chrome blocks that one, never had that issue before. I cant stop it blocking the file.
AMG KC
Re: Sega Model 2 UI
« Reply #32 on: April 23, 2019, 07:56:10 am »
Do you have a link to your Model 3 GUI thread??
Nuexzz
AMG KC
Re: Sega Model 2 UI
« Reply #34 on: April 23, 2019, 08:00:16 am »
https://www.supermodel3.com/Forum/viewtopic.php?f=3&t=1636
Thanks mate ;)
Ill check it out now.
Ive been struggling to get the G29 controls working well in the Daytona 3 and Sega Racing Classic, they work so well in M2 Emu. Seems very non-linear in SRC and Daytona 3.
AMG KC
Re: Sega Model 2 UI
« Reply #35 on: April 23, 2019, 08:04:40 am »
Now im not able to download it at all because it says ive reached the limit.
Is there another download mirror?
AMG KC
Re: Sega Model 2 UI
« Reply #36 on: April 23, 2019, 01:20:03 pm »
Finally got to download that, and it is awesome :) Makes it so much better!!
Thanks mate :)
Barry Barcrest
  • Last login:November 09, 2021, 09:54:17 am
  • Simple Plan
    • E-Touch Jukebox
Re: Sega Model 2 UI
« Reply #37 on: April 25, 2019, 04:30:41 am »
Am i correct in thinking that this is just passing the command switches to the emulator? It would be nice if you added an additional button to save out an ini file with the settings in. It has been a while since i looked at this but I have put an emulation machine together and so I am starting to dig into the emulators a little. I can't remember it uses on ini with settings for each game or separate ini files...
I am just thinking if you offered the ability to output to the ini file it would make your tool useful for configuring the emulator when calling it from a front end.
AMG KC
Re: Sega Model 2 UI
« Reply #38 on: April 25, 2019, 06:25:16 am »
One .ini for the whole emulator, and each game saves a file in the config folder for settings and buttons.
negative1
  • Last login:February 04, 2024, 04:06:51 pm
Re: Sega Model 2 UI
« Reply #39 on: May 01, 2019, 06:59:20 pm »
thanks, but getting a virus detected from the download, so deleted.
later
-1
