Author Topic: Key Wiz Questions  (Read 1175 times)
PacManess
  • Last login:August 19, 2007, 01:55:00 am
  • "Sue...I think she has a power pellet. *GULP*"
Key Wiz Questions
« on: February 10, 2004, 07:05:33 pm »
I know it's all be talked about before...but what is the big dif between the Key Wiz and the IPac? I mean, the slots on the Key Wiz, are they labeled like "A", "B", "Lft Shft" or like "P1 Up", "P1 SW1"...you know what I mean?
Pete Harcoff
  • Last login:May 29, 2005, 07:47:46 pm
Re:Key Wiz Questions
« Reply #1 on: February 10, 2004, 07:10:43 pm »
I don't know of all the differences, but there's 4 more inputs on the KeyWiz and it's about $5 cheaper.
However, the I-Pac offers USB support and (I think) keyboard pass-through support w/o requiring a switch.
Personally, I use the KeyWiz.  I found it very easy to wire and setup (mainly because all the inputs were predefined for MAME).  Not to mention it was cheaper.
PacManess
« Reply #2 on: February 10, 2004, 07:13:42 pm »
I've already got the IPAC, which is part of my problem...but with the KeyWiz Max, is it for 2 players or is it set up for 4?
You mentioned 30-something inputs, so I'm betting 2 players. Which is a-ok with me.
So, how are the inputs labeled on the KeyWiz?
Gideon
  • Last login:January 26, 2022, 04:36:33 pm
« Reply #3 on: February 10, 2004, 07:21:45 pm »
This comparison page has been cited in the past when this question comes up.
Pete Harcoff
« Reply #4 on: February 10, 2004, 07:25:32 pm »
The KeyWiz is designed for 2 players.
8 of the inputs are labeled Up/Down/Left/Right for Player 1 and Player 2.  8 of the inputs are labeled 1-8 (8 buttons for Player 1).  Then there are 16 inputs labeled A through P (8 buttons for Player 2, plus 3 coin buttons, two start buttons, Enter, Tab and Esc).  There are also two ground terminals, a +5 Volt terminal and an input for the shift (Shazaam) key.
Apparently you can program your own keys, but I just stuck to the defaults.
Oh yeah, it comes with a chart that tells you all the key defaults for each terminal on the board.
« Last Edit: February 10, 2004, 07:26:07 pm by Pete Harcoff »
PacManess
« Reply #5 on: February 10, 2004, 07:33:40 pm »
Thanks for the info...that is much helpful!
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
« Reply #6 on: February 11, 2004, 05:07:00 am »
Here is some pics of the keywiz up close, in case anyone wants to see it.
groovy~
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
GroovyTuesdaY
« Reply #7 on: February 11, 2004, 05:16:14 am »
another from a different angle.....
hehehe
PacManess
« Reply #8 on: February 11, 2004, 06:25:50 am »
Thanks man, that is helpful. I went ahead and ordered one last night, good times.
I will burn the old board and start anew.
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: February 11, 2004, 07:09:02 am »
This may be a little after the fact, but I thought I should mention it.
The KeyWiz has 32 inputs.  Whether it supports 2 or 4 players is up to you with any encoder.
For example, the I-PAC inputs are labelled 1SW1 thru 1SW8.  This is simple for someone new to the hobby, but confusing for an intermediate user.  For example, if I only want six buttons per player, I can always use P1B7 for an admin function, P3 joystick input, etc.
The same logic applies to the KeyWiz - with 32 inputs you have P1 and P2 with 9 buttons, and coin and start and pause and escape, OR you have P1 through P4 with 3 buttons each plus coin and start, OR (if you take advantage of stealth-shift functionality), you can support 4 players with 4 buttons each.
See http://www.fraggersxtreme.com/arcadepanels/encoder/shiftkeys.htm for a definition of stealth-shifted inputs, and http://www.fraggersxtreme.com/arcadepanels/encoder/keyassignments.htm for an example of maximizing the inputs from your encoder.
Just my 2 cents.
maraxle
« Reply #10 on: February 11, 2004, 07:52:43 am »
I went with the KeyWiz solely because with the shipping, it came out a fair amount cheaper than the Ipac.  Other than that, they were pretty much equal in my mind.
NoOne=NBA=
« Reply #11 on: February 11, 2004, 08:38:36 am »
The biggest difference is the USB support.
I've got a few old Macs, which will likely end up on cabinet duty as I get my new cabs done, so I opted for I-Pacs.
As far as the wiring goes, as Tiger-Heli mentioned above a connection is a connection for the most part.
If you want to hook a joystick to the extra "button" connections, you just have to remap the keys in the software to reflect that.
JamesS
  • Last login:May 09, 2014, 03:26:43 pm
  • Just getting Started, Bare with me...
« Reply #12 on: February 11, 2004, 09:12:27 am »
I bought the Keywiz simply because of price.  That was my only reason.  They both compare favorably, they both have everything you need.  The difference is the options and I did not feel the money was worth the difference.  But that is me.  I am enjoying my Keywiz right now, so right now it was the perfect choice.
