Main > Main Forum
Control Panel Advice
Pages: << < (2/3) > >>
Bomber:
--- Quote from: Witchboard on February 10, 2004, 04:22:48 pm ---What about head to head Twinkle Star Sprites or Magical Drop?  The games are vertical but I'm not sure if it works the way I'm thinking.
Both good games - but both horizontal. I'm going to stick to verticals as its a pretty small monitor so want to use all the available screen size.
slicer_d:
What about 1941?  I know strikers 1945 is two player but not sure about the older 1941 2 3  series.  Also I dont know if you play them but games like Raiden donpachin and dodonpachi (SP$) are newer but fun games to play on a vertical monitor.  There are a lot of newer 2 player games that are a lot of fun but limiting yourself to older games basically kills most of the simultaneous ones.  Also I would use 3-4 buttons if you go with more than classic games.
There is also a website that sorts all the vertical games for you but I cant remeber what it is at the moment if I can find it I will post it later.
Witchboard:
--- Quote from: Bomber on February 10, 2004, 05:21:24 pm ---
Come to think of it,  I don't think there are any vertical games for Neo-Geo like what you are wanting.  If you do like shooters, there are several that are really fun double player.
Bomber:
Thanks for the replies.
How about the t-stik plus. Has anybody had any experience with one of these? Is the switching from 4-way to 8-way tight enough that it won't accidently happen during gameplay? And does the 4-way mode feel like a true 4-way?
eightbit:
--- Quote from: Bomber on February 11, 2004, 05:59:59 pm ---Thanks for the replies.
I do not have a t-stick plus but I have a t-stick. It should have the same feel when its switched and I like the 4-way mode very much. Other people have reported that the t-stick plus has a positive detent that will not switch automatically yet is easy to switch when you want it to.
Go to full version
