i have an X- Arcade Dual Tankstick with an Trackball , i dont know the details on it if its an 24 tooth encoder disc
in Mame you have X Sensivity Y Sensivity , & Digital Speed Settings that are default set to 30
I never played Marble Madness or Crystal Castles i get the feeling i have to roll that Trackball hard to move quick
anybody with the right settings to get it to feel right ?
Unfortunately, there is no 'right' setting. You have to play with what works for you.
I like to play them with more sensitivity, so my settings will make it seem faster than
what the normal arcade settings probably.
When you play it, you just have to try different settings, and play with what seems most
comfortable for you. If you are getting scores similar to what you got on the arcade versions,
then you know you are on the right track.
good luck.
later
-1
