Main > Woodworking
Arcade Plans for Narrow Stairs?
jdevane:
I took a set of Galaga full scale plans and chop the back half off and will be using a 39" led tv mounted vertically as my screen which will also show the bezel and marquee for a near perfect sized original gameplay field. The Cabinet retains it's original width of 24" or so but is still heavy enough to not move around while playing. I actually just tested the tv and the little windows 10 mini pc, I have a big 24" x 36" lexan sheet for my screen cover which I will outline with black vinyl. I could actually get away using the tv speakers but I will install a 4" speaker as planned. I also want to run a top vent fan but a 120mm fan touches the back of the tv and the back of my interior support pieces so I haven't decided if that is needed or not. When I get more finished, who knows when that will be, I will do a full post/write up. I have a vinyl cutter that I can put a pen in and draw on paper so that's how I make my templates for cutting out my wood. I also have a QBert I wanna do but instead of chopping the back half off I am going to try just shrinking the depth of the cabinet in half to retain its shape....
With the Galaga, I can actually order a set of repo graphics for the whole thing and they will fit, the sideart will have to go down like Arcade1up did but I think it will look good still, rather have it big than shrunk. Added a photo to show what I mean of my Galaga adjustments.
Zebidee:
LCD TVs are fantastic for people with narrow stairwells
ark_ader:
--- Quote from: Demon-Seed on December 29, 2018, 10:07:50 am ---Hey Guys,
It has been a long time!!! Been over a decade since I built a cab! Well I am back and looking at building a slim that will fit up my narrow/steep stairs to my attic. I am after a slim full standup fighter style that I can fit up the steep stairs. Is there any plans or suggestions? I would appreciate it. My 11 year old is pumped to design one. It has been some time... and I have the itch. I do have most of the controls! Just need a tv and few other parts. Also will be looking for artwork designs if anyone has suggestions for who/where to go....
take care.....
Jim
Buy an Arcade 1up, buy some Ply or MDF, trace out the cuts, put the Arcade 1up back in the box and take it back. Or if you can get one for $150 get your son to put it together. I have built cabs for the basement only to leave it there or put a sledgehammer through it. It is great way to see how it comes together, then the second iteration you make will be much better.
barrymossel:
--- Quote from: jdevane on December 31, 2018, 11:05:57 pm ---I took a set of Galaga full scale plans and chop the back half off and will be using a 39" led tv mounted vertically as my screen which will also show the bezel and marquee for a near perfect sized original gameplay field. The Cabinet retains it's original width of 24" or so but is still heavy enough to not move around while playing. I actually just tested the tv and the little windows 10 mini pc, I have a big 24" x 36" lexan sheet for my screen cover which I will outline with black vinyl. I could actually get away using the tv speakers but I will install a 4" speaker as planned. I also want to run a top vent fan but a 120mm fan touches the back of the tv and the back of my interior support pieces so I haven't decided if that is needed or not. When I get more finished, who knows when that will be, I will do a full post/write up. I have a vinyl cutter that I can put a pen in and draw on paper so that's how I make my templates for cutting out my wood. I also have a QBert I wanna do but instead of chopping the back half off I am going to try just shrinking the depth of the cabinet in half to retain its shape....
Or try this:
http://forum.arcadecontrols.com/index.php/topic,157647.0.html
bperkins01:
My cabinet is 25" deep at the widest point with the CP removed. Uses a 32" LDC - full set up Sketchup plans too
Someone of the forum wisely told me - don't make it too big if its not needed - they were right!
Navigation
[0] Message Index
[*] Previous page
Go to full version
