Author Topic: Need help with my G-LOC Motor Driver Boards / SEGA 400-5117 (SOLVED)  (Read 15299 times)
perjmolsen
  • Last login:December 08, 2022, 04:09:06 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
Hi
I think that in this forum there is someone who might be able to help me (grantspain or princess pin pin)  ;D
My issue is that i have three defective G-LOC Motor Driver Boards / cages.
I have one fully working cage but I need two in order to get the movement working.
I have managed to get all the correct voltages present, but when I test them in my Sega g-loc deluxe there is no movement.
 (only movement if i mount the one powersupply that there is working)
The last year i have tried to find out why, but i have not been able to solve the issue, so therefor I reach out to you in my last hope that some one can help me.
I have followed the super guide in a french forum written by the user GC339 here https://www.gamoover.net/Forums/index.php?topic=28660.0
Restoration steps 1 to 8 is spot on, so my low voltage power supply is working, but when i need to figure out how to find the error in the control logic (Step 9) I am giving up...
I am willing to ship the cages and all my components for repair and also some money to that person who might be able to help me.
I have uploaded an Excel/Open office file to dropbox, and marked all the components green that i have changed.
Components marked brown i have tested in circuit, and yellow the components i think is related to the logic movement part.
See the tab "Repair log module 3" for all the parts that i have changed/tested on this board.
(also changed all the zener diodes ZD03->ZD11 (because when for two years ago when i successful repaired a driver cage the reason for the missing movement where some bad Zener diodes)
https://www.dropbox.com/s/cajy4szrq1bybzj/Nomenclature.ods?dl=0
Hopefully someone can guide me in the right direction in what i need to test/change in order to get the final movement part working  :applaud: :applaud:
Note if anyone has restored a Sega Radmobile deluxe - then it is the same PSU/Driver cage.
« Last Edit: January 18, 2019, 05:15:29 am by perjmolsen »
perjmolsen
    • My gameroom
Re: Need help with my G-LOC Motor Driver Boards / SEGA 400-5117
« Reply #1 on: December 12, 2018, 06:39:06 am »
YES YES YES - Finnaly!! (again) I now have movement!!   :)
ITS ALIVE !!! :)
I have read CG339's guide over and over... and finnaly i managed to put two and two together :)
in this -> https://www.gamoover.net/Forums/index.php?topic=28406.msg453283#msg453283  tread where he shows a diagram of the control logic, he mentions PC7,PC8,PC9 and PC10 as components who isolates the high voltage and low voltage...
So i where thinking  ;).. maybe they are dead, and i did not know how to test them so i swaped them with some new
So if you have all the correct volts, checked for burned traces.. but no movement then change
PC7,PC8,PC9,PC10 then you have movement.
I have updated my repair log on module 3 -> https://www.dropbox.com/s/cajy4szrq1bybzj/Nomenclature.ods?dl=0
« Last Edit: December 12, 2018, 09:00:49 am by perjmolsen »
  • Last login:November 18, 2025, 06:16:18 am
« Reply #2 on: December 12, 2018, 02:50:28 pm »
Thank you for sharing even though nobody here was able to help you.  :cheers:
baritonomarchetto
  • Last login:Yesterday at 01:50:15 am
« Reply #3 on: December 13, 2018, 12:30:48 am »
Thanks for sharing, great work
perjmolsen
    • My gameroom
« Reply #4 on: December 13, 2018, 08:11:45 am »
Thanks  :cheers:
perjmolsen
    • My gameroom
« Reply #5 on: December 13, 2018, 08:12:11 am »
perjmolsen
    • My gameroom
« Reply #6 on: December 13, 2018, 08:27:04 am »
If someone needs the service manual for adjusting the pontometers or greasing, then you can get a copy of my manual here:
https://www.dropbox.com/s/h9qqlehvooe2qqa/Sega%20g-loc%20service%20manual.zip?dl=0
Dave11674
  • Last login:December 29, 2022, 01:32:34 pm
Re: Need help with my G-LOC Motor Driver Boards / SEGA 400-5117 (SOLVED)
« Reply #7 on: April 14, 2020, 06:39:34 pm »
Hi
may i ask which type zener diodes you used to replace ZD03->ZD11
i have a board with burnt tracks etc
and these diodes are blown also
thanks
dave
perjmolsen
    • My gameroom
« Reply #8 on: April 15, 2020, 02:46:10 am »
Hi Dave
ZD3-ZD11 is 16V zener diodes.
ZD1-ZD2 is 13V Zener diodes.
In my repair log document, I have made some notes you can get it here
https://www.dropbox.com/s/yrrvg197yuiydsa/Repair%20log%20sega%20g-loc.ods?dl=0
Dave11674
« Reply #9 on: April 22, 2020, 09:29:39 am »
ahh i see now,
thanks
i have a few burnt out tracks
is it still wise to carry on as i was advised to bin it if so
few resistors burnt out too
where did you find PC910 ocot's ? i cant seem to source any
thanks
dave
« Last Edit: April 22, 2020, 09:42:43 am by Dave11674 »
perjmolsen
    • My gameroom
« Reply #10 on: April 22, 2020, 10:45:18 am »
Hi
On aliexpress I get nearly all my parts.
If you choose aliexpress standard shipping, you normal get your parts whitin 14 days.
When changing the pc910 put in some ic sockets. Then they are easier to change next time.
#Aliexpress DKK 13.89  14%OFF | 10pcs/lot PC910L PC910 DIP-8
https://a.aliexpress.com/_BO1anj
Dave11674
« Reply #11 on: April 23, 2020, 12:42:18 pm »
many thanks :)
im basically just going to order what you changed, but order like 25 of each component as it works out cheaper.
hopefully the other lots are easy to find too :) im close to farnells so can order resistors and what not there
i have a huge selection of caps at my disposal im im always recapping monitors at work, we have over 300 machines on site :)
keeps me busy :)
on a side note, the motor, if it was this that blew the board, how can i test it before connecting it all back up ?
i tested the motor board with my light bulb in the output power connector, not a sausage, but then again i do have lots of burnt tracks :-\
i have 2 of the 4 sections blown on my board, so will need to strip the sections down and basically shotgun all 4 with new components :) just to be safe :)
thanks
dave
perjmolsen
    • My gameroom
« Reply #12 on: April 24, 2020, 04:40:53 am »
Hi Dave
Yes, I always also order a load of components, then if it breaks again I have the parts needed.  ;D
(see picture below) :o
I think that the component that broke your board is one or more of the big diodes on the H bridge. (D20 to D27)
So before powering it up, pull them out and test them, I have repaired four of those PSU's and on them all it where one or two of the diodes that had blown.
Also remember to check the mylar insulator behind the diodes for small holes, better replace them all.
I got my diodes  from alibaba.com, I could not find them on ebay or aliexpress.
(S20LCA20/S20LC40) maybe S20LC20U if you have theSEGA 400-5117Y version
I THNIK that it is caused because they get hot, so on my PSU I have replaced all the insulators, and also added small heat fins also, the heat fins (see picture below).
So far the two psu's are running without any issues. :applaud:
I think that the diodes blow up because they burn thru/or the insulator get old, so they short out on the bridge.
I you are so unlucky that one of your L2 transformers are bad, then let me know.
I got some new one made in china, and I have before helped one in Australia with a new L2 transformer.(see picture below)  :cheers:
When I checked my motors, I just pulled out the motor brushes and looked if they where fine, and they where.
When I repaired my PSU's I followed GC339's guide step by step.
I also replaced ALL the electrolytic caps, because if just one are bad it can give some stange faults, and they are cheap and easy to replace.
I Hope that you get your PSU's and G-loc running again ;D Just write if I can help I will
Kind regards
Per
Denmark
« Last Edit: April 24, 2020, 04:47:57 am by perjmolsen »
Dave11674
« Reply #13 on: May 03, 2020, 10:09:39 am »
nice collection mate :)
how do i know which version of drive bd i have ?
ill add a pic shortly
i may just replace all components in the 4 sections on that side just to be sure
i noticed this bd had already been recapped too
hopefully i can pull all parts needed from you spreadsheet ;)
dave
EDIT1
diodes D04-D08
you have a couple as changed but ?? as parts, how did you change without knowing what parts ro buy :)
and any diode with s118 is a 1N4148 ?
dave
EDIT2
fancy putting me a full kit together :)
and selling said kit to me :)
i dont mind shotgunning if it gets this board back up and running
EDIT3
IC02   TA7538P<<<<<ahh u miss typed :) component check with eye.exe says its TA75358P  ;)
TR1   T10ABG-----I cant seem to find on ali express mate, any ideas ?
EDIT4
please show me how you attached the cooling fins
and where i can get them exact ones from
thanks
dave
« Last Edit: May 03, 2020, 12:46:28 pm by Dave11674 »
Dave11674
perjmolsen
    • My gameroom
« Reply #15 on: May 04, 2020, 01:56:35 am »
Hi Dave
Diode D04-D08
S118 is a 1N4148 diode.   :)
IC02 is a TA75358P  :D
TR1 can be replaced wit a BT138-600E I have forgot to put that into my repair sheet.
-> https://www.aliexpress.com/item/32953369205.html?spm=a2g0o.productlist.0.0.727b7976A0k3QI&algo_pvid=fd2f8247-3600-4775-a7e0-fa4a8bc7a8b8&algo_expid=fd2f8247-3600-4775-a7e0-fa4a8bc7a8b8-4&btsid=0ab50f6115885708618697414e78fa&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
The cooling fins I have attached to the big diodes D20 - D27 with the screws that normal holds them to the bracket, I have just put in some longer screws.
From the bracket I have put in a new mylar, then the diode, added some cooling paste on the diode and then the cooling fin.
You can get a set of 10 mylar and 10 cooling fins here
https://www.aliexpress.com/item/32853525781.html?spm=a2g0o.productlist.0.0.18eb2036vNWZ5V&algo_pvid=da582055-8e04-43d4-b8eb-f4831be8bf2e&algo_expid=da582055-8e04-43d4-b8eb-f4831be8bf2e-0&btsid=0ab6f82415885714401997659e208d&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Dave11674
« Reply #16 on: May 04, 2020, 06:33:54 am »
Thanks mate
All parts now ordered ;)
Dave
perjmolsen
    • My gameroom
« Reply #17 on: May 04, 2020, 08:02:24 am »
Super  :cheers:
Make some repair notes, and take pictures, if you descover anything that later might be useful
Then make a small repair log - I LOVE to read repair logs !
Maybe you can find some information that you can use in my logs of reparing my driver boards
https://www.gamoover.net/Forums/index.php?topic=36585.0
https://www.gamoover.net/Forums/index.php?topic=40992.0
« Last Edit: May 04, 2020, 08:05:29 am by perjmolsen »
dioŠ
  • Last login:October 02, 2023, 12:02:20 pm
« Reply #18 on: May 26, 2020, 02:18:16 pm »
hi, I would to download the manual but I can't, it says:
"404
That file isn’t here anymore"
perjmolsen
    • My gameroom
dioŠ
« Reply #20 on: June 07, 2020, 09:17:37 am »
Hi
I just uploaded the file
https://www.dropbox.com/s/mtv58tl8qsdkfr8/Sega%20g-loc%20service%20manual.zip?dl=0
Kind regards
Per
thank you very much.
do you think you can do the full scan further on?
talasemia
  • Last login:March 08, 2021, 06:08:59 am
« Reply #21 on: February 26, 2021, 04:22:32 am »
Hi
Kind regards
Per
Hello!
I'm Alex, from Barcelona, ​​Spain. I recently got a G-Loc deluxe, but it is in very bad shape. I am carefully following your repair, amazing job! Congratulations. I am working on getting the images to reproduce the stickers (red warnings and GLOC's own), but it is almost impossible. Could you tell me how to get them? I am also looking for the service manual, but another mission almost impossible.
I try to download your file from dropbox, but it´s removed. Can you share again the file please? Thanks in advance!!
dioŠ
« Reply #22 on: May 07, 2021, 11:30:57 am »
sorry if I resume this thread but I have some problems similar to my g-loc deluxe and I need the owner's manual but unfortunately it is no longer available for download. could someone upload it to me again? thank you
dioŠ
« Reply #23 on: July 04, 2021, 01:16:22 pm »
no one has the owner's manual anymore?
perjmolsen
    • My gameroom
« Reply #24 on: November 29, 2022, 05:30:18 am »
Hello
Sorry for the late answer, but I did not get any notifications.
Here is the manual
https://www.dropbox.com/s/lpldflxt2jr8nee/Sega%20g-loc%20service%20manual.zip?dl=0
