Main > Project Announcements
Pac-Man Legion
<< < (12/77) > >>
Jimbo:
Niiiice work... :)
Is that joystick hole big enough for the joystick to move?
javeryh:
Wow Ond... looks like it was made by a machine.  So smooth...   :applaud:
I'm also wondering if the joystick hole is wide enough but I'm sure you've thought of it.  So you are making 2 of these I assume?
Ond:
--- Quote from: wp34 on March 17, 2019, 09:28:53 am ---
--- Quote from: J_K_M_A_N on March 17, 2019, 08:43:06 am ---As always, that looks amazing. If you had a live web cam, I would probably watch that for hours. :) Incredible work!
J_K_M_A_N
Ditto.  I'm not a big video guy but if you had a Youtube channel I would subscribe.
Excellent work.   :applaud:
Thanks fellas, I could do some videos of stuff that might be useful.  I'll see what I can do.
--- Quote from: Jimbo on March 17, 2019, 10:49:24 am ---Niiiice work... :)
--- Quote from: javeryh on March 17, 2019, 11:09:24 am ---Wow Ond... looks like it was made by a machine.  So smooth...   :applaud:
Thanks guys, I'm getting closer to the look I visualised for this cabinet, as always it’s all in the surface preparation before paint goes on.  The joystick hole is a close fit, probably too close once all the surface finish is done.  The test fit of the joystick was fine, with the stick clearing the hole when pushed in any direction but I'll enlarge it before paint goes on. I have to buy an additional hole cutter for metal.  The small hole did allow me to perfectly align the stick for bolt placement, so it's all good.  I am making two CPs, the other one is still at the pre-fiberglass stage (with steel plate fitted).
I've been teaching myself all there is to know about applying 3M Vinyl wrap.  That stuff is designed to adhere to a highly polished automotive paint finish so it should work really well on these panels.
  I've also come up with what I think is a cool (pun not intended) way to ventilate this cabinet. Airflow will be fan forced from the base plate of the cabinet using the biggest PC fan I can find, flow up around the base of the CRT tube and out underneath each CP.  The vents under each CP will double as speaker grills of a sort.  I'll concept that up in a render so you can all see what I'm on about.
jennifer:
Great choice with the wrap, That will bring this up to the modern conceptual I would imagine you are going for...Heat rises, good use of physics, Jenn dont need to be spoon fed image cad to see awesome. ;)
javeryh:
Any updates Ond?  Or is it the middle of winter and impossible to work?
Navigation
Message Index
Next page
Previous page
Go to full version
