Hi, we are working with a trisync monitor in a DDR cabinet and are trying to upgrade the hard drive in the computer it is attached to. In the process, we installed Windows 10 and forced the desktop resolution to 640x480. When the resolution is not set to this, the monitor flickers and makes arcing noises. Even though we were able to set the correct resolution and it works fine once it gets to desktop, the Windows 10 boot screen (with the spinning dots) is not 640x480 (I am assuming this is the problem) so the flickering occurs until it gets past that screen.
My questions are:
Is this screen flickering potentially damaging to the monitor?
Is there any way to either disable the boot screen or change the resolution of the boot screen of Windows 10?
I tried GUI boot off in boot menu options, but the problem continues.
