Author Topic: Moire effect / wavy lines on some resolutions  (Read 16838 times)
Sublevel
  • Last login:March 19, 2019, 04:49:47 am
« on: November 05, 2018, 04:23:34 am »
*Update: It seems i need some kind of a Low Pass Filter between the VGA ouput and JPAC input. Original post down below.
In most of the games i've tried i get this annoying moire effect when the screen is scrolling vertically (or horizontally when i have the monitor in horzontal position). I also get this ringing effect on the edge of sprites/backgrounds like the picture is too sharp. However, in games like Ketsui and Espagaluda which both run at 448x224 @ 59.17Hz i do not get the moire effect. How come? Has it something to do with integer scaling?
Please see attached logs. In ESP Ra.De. i get the moire effect but not in Ketsui.
My setup looks like this:
Dedicated Groovymame computer (Win7, Radeon 5450) inside an New Astro City > VGA > JPAC > JAMMA connector > Nanao MS929 monitor rotated vertically
Things i've already tried:
Different presets/monitor settings in VMMAKER
Replace VGA cables
Replace video card
Replace computer PSU
Replace step-down converter for the NAC
Moving cables around inside the NAC
Adjusting pots on the Nanao monitor (adjusting focus somewhat hides the moire)
« Last Edit: December 03, 2018, 04:39:14 am by Sublevel »
  • Last login:April 10, 2024, 02:02:31 pm
Re: Moire effect / wavy lines on some resolutions
« Reply #1 on: November 05, 2018, 05:01:48 am »
Just in case, try with normal resolutions instead of super resolutions. E.g. add 320x240@60 to the list of super resolutions, and generate and install the list of modes, then launch esprade.
Sublevel
« Reply #2 on: November 05, 2018, 05:13:14 am »
Thanks Calamity, will try that when i get home tonight. But if i remember correctly, in the past i've tried installing normal resolutions instead of super resolutions with the same moire effect in game. However, i did notice the moire effect was gone when using normal resolutions and checking stuff in ArcadeOSD, but when starting Groovymame the moire was back again.
« Reply #3 on: November 05, 2018, 05:27:25 am »
In your logs, I can see this error:
Direct3D: Unable to find D3DXCreateEffectFromFileW
I don't know if it could have any relation to the issue. I see this very often in users' logs. I'm not sure if it's caused by not having the proper DirectX distributables or by a mismatch between GM's exectuble and the rest of files in its folder. I recommend to get the full package from my Google drive site.
cools
  • Last login:March 11, 2024, 02:59:06 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #4 on: November 05, 2018, 07:14:16 am »
I'm getting this on the only machine I've updated to 203, and I'm using the full package (had to recreated my mame.ini  :lol). I can't confirm whether I have correct DirectX or not, it's Windows 7 Home Premium 64bit. I'm having performance/sync issues with the machine too so would like to resolve it and see if that fixes them
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
« Reply #5 on: November 05, 2018, 09:14:58 am »
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
cools
    • Arcade Otaku
« Reply #6 on: November 05, 2018, 04:45:48 pm »
Thanks, that fixed the message but not the problem, which I'll follow up in another thread.
Sublevel
« Reply #7 on: November 06, 2018, 03:17:21 am »
Tried normal resolutions and installed the Full DirectX9 package and i still got the moire effect in game. The monitor chassis recently got recapped and the image quality is sharp as hell complete with ringing around sprite edges. When i defocus the monitor with the focus pot (or using bilinear filtering in mame) the moire/ringing is somewhat reduced, but then i also get convergence issues so that solution is a no go. Could it be that this monitor combined with JPAC/VGA input is just too sharp for it's own good? And that the resolution for Ketsui (448x224) somehow comes out as slightly blurrier than Esprade (240x320) which eliminates the moire effect? Just a wild guess.
« Last Edit: November 06, 2018, 03:24:07 am by Sublevel »
« Reply #8 on: November 06, 2018, 03:24:36 am »
You'd better post some pictures of your real screen (and probably delete that one of a NEC monitor on your first post that's quite misleading).
Is the ringing around the sprite edges something really all around the sprites or just on the right side, like a shadow?
Sublevel
« Reply #9 on: November 06, 2018, 03:35:44 am »
I will take some pictures and post later today. If i remember correctly it's all around the sprites, not like a shadow effect.
Paradroid
  • Last login:Yesterday at 05:20:15 am
    • SCART Hunter
« Reply #10 on: November 06, 2018, 04:21:21 am »
Sorry to threadjack but I have the exact issue you described with a TV that I recently RGB-modded (right-side shadow that trails any sudden change of contrast or color).
Interested to hear your theory if you had one...
Sent from my SM-G955F using Tapatalk
« Reply #11 on: November 06, 2018, 04:43:19 am »
My Polostar did this too, and it sucked for that. It was fixable to some extent adjusting the contrast down (or maybe the brighness?). It probably has some simple explanation from an electronics point of view, for some reason it can't resolve those sudden changes in the signal.
Sublevel
« Reply #12 on: November 06, 2018, 06:46:41 am »
Oh by the way, does "filter 1" add any input lag to Groovymame?
« Reply #13 on: November 06, 2018, 07:19:50 am »
It doesn't add lag, but it degrades the image.
Sublevel
« Reply #14 on: November 07, 2018, 04:12:20 pm »
Please see attached pictures. The ArcadeOSD one shows the moire effect and the rest the ringing on pixel edges.
« Reply #15 on: November 07, 2018, 04:19:47 pm »
I see. Thanks for the pics.
Have you tried calibrating the contrast?
Sublevel
« Reply #16 on: November 08, 2018, 09:08:33 am »
Yes, and to no avail. It should also be said that my cab came directly from japan complete with the original power supply and ISO transformer still connected. I haven't rerouted any cables myself so i don't really know if everything is hooked up correctly regarding grounding etc.
pakoman
  • Last login:Yesterday at 09:24:39 am
« Reply #17 on: November 08, 2018, 09:57:35 am »
I was going to suggest that: maybe a grounding or degauss issue? Is there any degauss switch in the cabinet?
Sometimes magnetized stains are related to the angle between the cabinet and north and just rotating the cabinet improves a lot.
Sublevel
« Reply #18 on: November 12, 2018, 04:47:18 am »
I played around with the cab this weekend and checked the grounding. I have no idea how grounding should be wired in this cab but there are a lot of green cables going from the back (inside) of the cab to different spots like the control panel, coin door etc. I moved them around a bit but didn't notice a difference. But if it was a grounding issue, shouldn't all games be affected? I want to point out that i only get this moire effect, no other noise or interference at all.
I also e-mailed Andy regarding the JPAC to hear if he had any idea and got this response: "It would normally be caused by a difference between the pitch of the resolution and the dot pitch of the CRT. The first thing to check is that the resolution is correct and matching the game. If it is, it must be the CRT. So the only way to overcome this would be to de-focus the monitor slightly or mess around with the convergence ring magnets although the latter is a risky approach."
So i tried messing around with the dot clock setting in ArcadeOSD and i can in fact "move" the moire around a bit by doing so, but it doesn't get rid of it. Any ideas how i should approach this further? Or should i just settle with defocusing the picture?
Thanks again all  :)
cools
    • Arcade Otaku
« Reply #19 on: November 12, 2018, 05:39:57 am »
What version of CRT_EmuDriver are you using?
(I think the ringing is a monitor setup problem, but having just spent lots of time finding a problem with my 5450 and the Crimson driver I figure it's worth asking)
« Reply #20 on: November 12, 2018, 06:02:09 am »
Ok, I've been thinking of your issue and I agree with Andy's diagnosis. Your CRT is just too sharp.
Now, you provided a clue that may lead us to a software fix. When you said Ketsui does not show the issue, I didn't notice that 448 scales on 2560 by a fractional factor, while Espagaluda is 320 pixels wide, that scales by a perfect integer factor of 8.
So it's probably fractional scaling what provides the slight blur you need to get rid of the interference pattern.
If that is true, there's something you could test. Instead of 2560x, use 2600x for all your super resolutions. Edit the user_super.ini file and replace all 2560 values by 2600. Then create and install the modes again.
I suggested 2600 because it's not a multiple of either 256, 264, 288, 320, 400, etc, so fractional scaling will be applied on the horizontal axis.
Sublevel
« Reply #21 on: November 14, 2018, 05:16:34 am »
Thanks for the suggestion Calamity, but sadly that didn't work. I still get the moire effect when installning 2600x*** modes. I also tried switching over to latest release of Catalyast 12.6 and there is no difference.
I've noticed that all vertical games with a resolution higher than 320x*** is free from this issue. I tried a game with a res of 384x240 (free from moire), please see attached log if that's in any way helpful. I noticed in the log a bit further down "orientation: normal". Shouldn't that be "rotate_r" as i have my monitor rotated vertically? Also, shouldn't vertical resolutions be listed as e.g. 240*384?
« Reply #22 on: November 14, 2018, 05:44:25 am »
No, GM is right there. Since you are using the rotate_r preset, "vertical" resolutions are turned into "horizontal" resolutions, so 384x240 is correct.
I'll try to think something else. Meanwhile, consider installing the DirectX package linked by Krick above, so you get rid of the error message at least.
pakoman
« Reply #23 on: November 14, 2018, 08:29:37 am »
What about playing a bit with the screen size (not resolution)? You will get black bars/ overscan, however you may find something balanced between screen size and moire effect.
Or even adjusting the geometry pots (Pinch Cushion, etc) of the monitor or adding a small amount of divergence to one of the colors may help.
Evewalker
  • Last login:November 29, 2018, 09:17:03 am
« Reply #24 on: November 14, 2018, 01:42:54 pm »
Just to potentially add more data to help solve this issue, I have the same problem.   Ketsui and any game running at its resolution is perfect, but the wavy moire effect is present elsewhere.   I've tried everything from hardware and software swaps, cable replacements, and monitor adjustments with no improvement.
I can upload my logs later tonight, but to test, I did comparisons with a few actual PCBs which ran perfectly without the issue, while the GM versions had the disturbance.   The PCBs I tested were Donpachi and Strikers 1945.   The monitor is a Nanao MS8 29 FTB rotated vertically in an Egret 29.
Sublevel
« Reply #25 on: November 15, 2018, 03:35:41 am »
I did install the DirectX package but i guess i still get the error message. I extracted the files and ran the setup file in the main folder.
If i stretch the image vertically a lot by using the pots, the moire is somewhat reduced. But i have to stretch it so much it defeats the purpose. Minimizing the image does not help.
Sorry to hear you also got this problem. Please do upload your logs, thanks  :)
« Reply #26 on: November 15, 2018, 03:40:26 am »
I'd say what Pakoman meant was to use the software stretching options in MAME's internal ui, namely "Screen Horiz Stretch" under the "Slider Controls" menu.
schmerzkaufen
  • Last login:October 03, 2023, 02:27:31 pm
« Reply #27 on: November 15, 2018, 04:44:49 am »
Can you try a different monitor ?
Also can't aging caps or flyback cause all kinds of weird issues that start showing with a select number of source signals and then with time expand to all ?
I've had a couple of old sets that would start acting only with certain sources before going all senile.
cools
    • Arcade Otaku
« Reply #28 on: November 15, 2018, 07:01:39 am »
I know you said you've tried them, but logs where you are using normal resolutions would be good.
I can understand why you *might* get moire with super resolutions (integer or fractional scaled), however it's baffling that it's occurring with normal resolutions.
Pics to accompany logs too please.
pakoman
« Reply #29 on: November 15, 2018, 09:10:28 am »
Well, I meant the pots in the monitor to avoid distorted scaling, but both options could do. And specially those that control the curvature of the screen (pinch cushion, pillow cushion...).
I remember from the times I used to collect jamma boards that Mame looked way darker than the same jamma board in the same arcade cabinet and gamma needed to be adjusted in Mame. That was a few years ago (AdvanceMame 0.106 dos IIRC, before old good Groovymame times :)), so I don't know if Mame improved in that regard nowadays. Maybe not the case, however, the darker the colours the more likely the moire effect to appear, the brighter and the more they "bleed" the more they hide moire effects, chequered patterns, sharp pixels, etc.
Could you just check the brightness levels in both Mame and jamma are the same?  Maybe the jamma board with darker colours also produces moire patterns...
« Reply #30 on: November 15, 2018, 11:28:04 am »
Yeah, that's the point. Anyway, both 320 (not necessarily other) and 2560 would be undistinguishable signal-wise (unless integer scaling is broken from some reason in the actual gpu).
I'd also like to see full screen pics of an affected game.
Evewalker
« Reply #31 on: November 17, 2018, 09:29:33 pm »
Here are some logs from my setup, both using Standard Resolutions, and Super Resolutions installed.
Ketsui has no moire effect at all.  Donpachi has a severe moire effect when scrolling using both Standard and Super Resolutions installed.  Using the actual PCB gives a functionally identical picture except for the lack of Moire effect and wavyness.
Evewalker
« Reply #32 on: November 17, 2018, 09:36:00 pm »
This was a good idea, and I did check this.  The arcade PCB as expected was a bit brighter, but I adjusted the brightness levels to match and the wavy effect was still there, unfortunately.
Zebidee
  • Last login:Yesterday at 01:18:46 am
« Reply #33 on: November 17, 2018, 10:48:35 pm »
Something obvious for you to try.
Make sure that your arcade monitor is grounded to nothing except itself. Make sure that it doesn't share ground with other parts of your cab.
Why? Because your arcade monitor is powered by an isolation transformer, which isolates your power supply and effectively provides a local ground for that circuit (. This way you won't get interference from the AC ground line, and it is actually safer too!
If your monitor doesn't have an ISO, then feel free to ignore this advice.
Sublevel
« Reply #34 on: November 19, 2018, 10:32:37 am »
I will try and post some pics and new logs tonight. It's difficult to find the time with a 1 year old son  :D
Thanks to all contributing to this thread so far!
If it was an grounding issue wouldn't all resolutions be affected? I don't think the monitor is grounded to anything special. There is a spring-like wire going around the monitor that attaches to the neckboard.
Zebidee
« Reply #35 on: November 19, 2018, 09:12:47 pm »
It could still be grounding, just the effects not apparent in all modes. However, that is just a theory. Leave that spring-like ground wire from tube to neckboard, you need that there. Usually there should be nothing connected between monitor chassis and ISO except 2 power lines (active and neutral).
One way to test the AC ground interference theory is to plug in something to the same powerboard/outlet that has a powerful electric motor, like a mixer/blender or a drill. See if running that makes a lot of interference.
Keeping video signal wires away from high voltage areas of the chassis like the flyback is always a good idea.
I have a suspicion that this moire effect is common in Nanaos. Many Many years ago I had an Astro Cab (like a Candy) with a 29" Nanao monitor and, iirc, I am sure that I had this same moire issue. I went over everything, including grounding, and didn't get any better than small improvements. I was using an ArcadeVGA and JPAC.
My Nanao was one of those dual-res ones that could do EGA (25khz) as well as CGA, but it was always set to CGA anyway. Can't remember the model, but it would have been ms8 or ms9.
All this leans toward Andy's diagnosis earlier, that the moire has something to do with a mis-match between phosphor dot-pitch and game resolution. Maybe the standard Nanao tube has a weird phosphor mix/layout/pitch to better suit EGA? However, I don't think that there is anything wrong with your convergence. Pic look good in that regard. Your monitor is not "too sharp". Leave the convergence rings alone.
Fiddling with focus/convergence might minimise moire, but only because it is harder to see everything through the fuzz.
If dot-pitch/resolution mismatch is the cause, you might find that the problem disappears with another tube! Anyway, you can't really test that without a matching tube lying around...
I also suspect that it is not CRT_emudriver causing the moire, as ArcadeVGA causes it too (if I am recalling correctly above, please test if you have an ArcadeVGA lying around).
Which brings us back to the JPAC. Maybe you could try running signals directly to your Nanao, bypassing the JPAC, to see what happens? The picture will be faint, for sure, but am interested to see what happens to the moire.
Evewalker notes that the problem goes away when running a PCB (ie no JPAC) vs MAME:
pakoman
« Reply #36 on: November 20, 2018, 10:04:38 am »
Then if the jamma / Groovymame are outputting the same signal (except for brightness! :P) the moire effect must be produced by the computer at some point...
Maybe the VGA cable / computer / etc is not shielded/grounded enough and some resolutions use more voltage than others. The computer speakers?
Have you tried adjusting slightly the V-Sync / H-Sync pots in the monitor?
From the computer side you may try a different computer, using AdvanceMame, avoiding the Jpac (direct connection VGA-Monitor), a different JPac, different electric sockets...
PS using CRT Shaders with a QHD monitor also produces moire effects
Zebidee
« Reply #37 on: November 20, 2018, 02:10:30 pm »
Even the best CRT monitors can show a moire effect if you put up the right test patterns.
I'm 99% convinced that the moire effect is caused by phosphor dot pitch being too large/wrong, and has nothing to do with PC, video card, PCB, JPAC, monitor chassis, grounding, AC interference or anything but the CRT tube itself.
It is another reason to avoid Nanao monitors, despite the fact that they often seem to be otherwise good (they are also difficult to repair).
I'd be on the lookout for a TV donor tube.
This site has a very simple explanation for the effect: http://www.displaymate.com/moire.html
Summary of ways to minimise moire:
1.    Some displays have "a Moiré Reduction Control" (but this might not be effective and may introduce artifacts)
 2.   Slightly de-focus the image using the monitor's focus control
3.    Adjust up contrast/brightness
4.    Use different resolutions.
5.    Avoid dim backgrounds.
6.    Avoid dithering, and avoid 16 color Windows modes, which generally have a lot of dithering. Dithering occurs much less frequently in 256 color modes and is generally absent in 32K color modes and above.
Evewalker
« Reply #38 on: November 20, 2018, 06:44:48 pm »
The problem is that no actual arcade PCBs, multiboards, or JAMMA test pattern generators display any sort of issue on the same monitor.  All display perfectly.  This problem is only coming up with a PC connected via a J-pac and GM.
I'm going to try a few different video cards tonight to see if that changes anything.  I have both 4000 and 5000 series AMD cards to try out, and I'll report back.
Zebidee
« Reply #39 on: November 20, 2018, 08:36:59 pm »
OK, sorry, maybe its a bit confusing because I thought someone (you!) was reporting that they got got the moire effect with PCB earlier:
But I see that you are NOT getting moire with PCBs now, at least with Donpachi and Strikers. Just a note about those games - they are vertical games with lots of horizontal lines (rotated to be vertical ofc), and Sublevel was reporting that he/she didn't get the moire effect with games that had many horz lines (more than 320 horz lines?).
It may also just come down to individual video modes (as people report moire in some modes, not others), and your PCBs are probably creating a different video mode (at least slightly different) to the one GM is choosing when you run the game, if you understand what I mean.
What I'm trying to say is: not getting moire when running those PCBs is not conclusive, we need more evidence.
I'd be very interested to hear about your moire outcomes from running PC/GM direct to the monitor, bypassing the JPAC.
