Main > Main Forum
Anyone ever use these?
Pages: << < (4/4)
GroovyTuesdaY:
I just ordered the one on ebay and im going to give it a shot when i wire my stuff next week. Hopefully it will go well :)  It was only 7 bucks. I figure it was worth the money to try it out anyways.   I am sick of using the one i have that is a basic  wire stipper/crimper.   Damn thing hurt my hand after about a half hour.
groovy~
Sylentwulf:
Got mine in, worked on the cables I tried it on pretty well, not TOO cheap feeling. I'll get my money's worth out of them at least.
shmokes:
Using your teeth is a bad idea.  You're going to rub the enamel off of them sliding metal wire across them repeatedly.  Who wants cavities in their front teeth (or any teeth for that matter)?
NoOne=NBA=:
--- Quote ---Using your teeth is a bad idea.
I didn't say it was a good idea, just that it's what I do.
Most of the wires I strip are 28 gauge, and I've never developed a good enough feel to use strippers or a blade to strip them.
On an 8-conductor I usually end up with 4 different lengths of wire using tools.
When you are trying to get them into a single connector end, it helps if they are all the same length, which they rarely are if I try to use tools.
GroovyTuesdaY:
Ok, i just got my quick strips in the mail today and let me tell you.....THESE THINGS ROCK!!!!!   I was in total giddiness after i tried stripping about 10 ends off.  OMG, my first thought was  "where the hell were these when i cut my wires for my four player panel!!"  My hands were so sore at it literally took me almost 7 hours to cut, strip and crimp the wires for my 4 player panel. I used a pair of normal 10.00 cutter, crimper , strippers from walmart.  Just the standard one.  With these new ones, i KNOW i can cut my time in half AT LEAST!
My final word is, for smaller wires like 22-28 gage, these quick strips should last a good long time. If your doing thick wires, i think the quick strips would probably break down at some point, but this is only a guess as i have not tried it. They just don't "Feel" or look like they are made to do thick wires, but my the one i got is just a medium size looking one, so i think it was made to be used on smaller gage stuff.
Anyways, i bought mine on ebay for 12.00 shipped! They are VERY MUCH worth it and i'm totally glad i bought them ,because i'm getting ready to do a couple of panels and this should make things go ALOT smoother!
groovy~
Pages: << < (4/4)
Go to full version
