Main > Project Announcements
Gingerballs 2.1 the rebuild starts
<< < (2/18) > >>
yotsuya:
I would think the CNC couldn’t cut the finger joints square enough.
Ian:
Watching this with much anticipation.
Mike A:
--- Quote from: yotsuya on August 26, 2018, 05:58:00 pm ---I would think the CNC couldn’t cut the finger joints square enough.
If you can mount the board perpendicular to the x axis instead of flat on it you can cut proper finger joints. Most CNC machines don't allow for this because it cuts down on the total work area.
yotsuya:
--- Quote from: Mike A on August 26, 2018, 09:42:10 pm ---
Hmmm... that makes sense. You’d need a pretty long/deep Z axis though.
Laythe:
I think that you can also do fingers if you're using a waterjet or laser.  (I didn't know if he was CNCing the kits that way, or on a mill / router.)
Navigation
Message Index
Next page
Previous page
Go to full version
