| Main > Project Announcements |
| My first real Cab pick up, Nintendo DK restore. |
| << < (12/15) > >> |
| paigeoliver:
Yes, the holes looks like it was a Donkey Kong converted to a single screen Playchoice. However what it was between then and now doesn't mean anything, this was a Donkey Kong. |
| Locke141:
I tried stripping the pain on one side. I was at my Dad’s to help him with out. Did a quick once over to see what I’d get. Here the original paint was in good shape. However I can see spots where the blue is damaged. It looks like some touching up is the minimum that will have to be done. Annoyingly I forgot my multimeter so could not test the power supply. |
| Locke141:
I picked up a nice reproduction bezel. Turned out to be an original. Was in really good shape. May I request a mod move this thread to project announcements? I would like to keep this in one thread. |
| Locke141:
Thanks Scott :cheers: --- Quote from: Crowquill on August 27, 2018, 06:16:09 pm ---The metal CP would have been an addition when they did the conversion. You'll need to replace it with wood and plexi if you want it to look right as DK. As for a second button, there's modified DK overlay artwork for multicades that have multiple buttons. --- End quote --- Is this what you had in mind? I think I'll probably go with a original stile CP. Then again this will be running MAME Are there any two player 4 way Vertical games I'm not thinking of I might want it to play? |
| Crowquill:
Originally I was thinking an original DK layout with an extra button added next to jump. Not finding an example of one now, but I've seen vector art online that could be printed and put under plexi. If you can't find one PM me and I'd be happy to edit one together. And now you've reached the big rabbit hole everyone here lingers over. What controls to add and what games do you value? How accurate do you want it to be to the original? With your 60-in-1 a 4-way and 2 buttons will let you play probably 40. If you care about shooters go with a 8-way and you'll be able to play 85%. Or add a trackball and you can play everything but Commando. Those boards let you disable games from the menu you don't have controls for. The average Joe who walks up to a machine doesn't like too many options. Give them too many j to pick from and they'll get frustrated and walk away. Or they'll just play Pac-Man. If you're doing a full MAME setup then sky's the limit. MAME can scale and center the image, so you could even play horizontal games on it. When I built my MAME cab 15+ years ago I wanted versatility. I went with the fairly standard horizontal computer monitor, 2-player panel with 8-way sticks and 7 buttons per side. It's a lot to squeeze onto a Frogger control panel. I've played LOTS of Donkey Kong with 8-ways and it's fine. If you hit a diagonal Mario will stop, but it's rare with the gameplay that you press diagonals outside of maybe ladder transitions. Sent from my XT1585 using Tapatalk |
| Navigation |
| Message Index |
| Next page |
| Previous page |
