Main > Software Forum
Keyboard2Xinput (Virtual X360 pads from keyboard)
Student123:
Dropping some knowledge on how to play TMNT Wrath of the mutants on 4 arcade controllers with an Ipac with Rocketlauncher \ Hyperspin
Step 1: Configure game to use keyboard2xinoput in your AHK
Step 2: Add the game to steam and configure it to overide with steam inputs, edit the controls to have the dpad control the sticks
Step 3: Add the following ini info for the game to load:
Application=steam://rungameid/11106784937863282688
Application=H:\PC Games\Teenage Mutant Ninja Turtles Arcade Wrath Of The Mutants\TMNT.exe
AppWaitExe=TMNT.exe
ExitMethod=Send Alt+F4
(you can create a shortcut in steam and it will tell your unique id, most likely different as it's a custom game)
This will work with 4 players, only way I could get my controllers to be recognized, without Steam keyboard2xinput would do nothing...
I was able to get street fighter 5 and 6 working with this methode as well
Hope this helps someone
If a anyone is able to bypass steam let me know, seems some game need the steam inputs to work, otherwise keyboard2xinput doesn not work with the game on its own.
Yardley:
--- Quote from: Student123 on April 26, 2024, 08:36:11 am ---
Use a non-Steam version of the game since you already purchased it anyway (hint hint). Have you noticed any issues with the player 1 movement while using your joystick? Seems to get stuck for me specifically moving diagonally.
Arcader626:
Hi @Schwing and thank you very much for this program. I own three IPAC 4 that I use in three arcade cabinets. I have been dealing with the problem of PC games that use exclusively Xinput devices using XOutput since years ago, but it always gave me problems because I could never get key interception. Now I have just began to use keyboard2xinput and it is the definitive solution. Perfect!
xul:
Hello,
Wanted to see if anyone has seen an issue with Tekken 8 and with Marvel Fighting collection. Keyboard2Xinput seems to work for like 20min or so and then all of the controls get mixed up and un-usable. I need to exit completely. I'm on the same build I was on previously. Windows 10. Using v1.2.2. I tried downloading 1.2.3 but the link doesnt work. http://kb2xi.schwingsk.net/Keyboard2Xinput-1.2.3.zip
xul:
--- Quote from: xul on October 22, 2024, 07:30:52 pm ---Hello,
I was able to download v.1.2.3 using a different browser. I'll test again using the new version... ;)
Navigation
[0] Message Index
[*] Previous page
Go to full version
