Main > Main Forum
Mame arcade overload!!!
Wade:
I'm not a monitor expert but that makes sense to me from a layman's perspective. So skip the arcadevga and use an big EGA or VGA monitor.
Wade
Nailz:
Paige, I despise you and all you stand for you bastard..... ;)
Actually, I just want to live vicariously through you, it's eough work just keeping what I have now (Mame cab and a Pac-Man). Women say they understand your stupid hobbies until you get married and then things change, because of course a big-ass yellow Pac-Man cab goes with nothing in a typical house so it must go to the garage, along with everything else you collect.
Although admittedly, the Pac-Man looks pretty good sitting next to the 66' Mustang Coupe my wife agreed to let me buy, so what the heck do I know? ;D
Anyways, enjoy your hobby and give us some damn pictures.
krick:
--- Quote from: paigeoliver on February 16, 2004, 01:51:11 am ---
--- Quote from: Wade on February 13, 2004, 09:09:20 am ---I don't know about the arcadevga problem you mention, probably deserves it's own thread.
It is the same thing with the vertical games. Their proper resolution makes them fill the entire screen, when they are turned and displayed with the black lines on the side, they MUST be scaled down somewhat. The exact same thing also holds true for using a television for a display, and is actually where I first witnessed the fact that you CAN tell, at least on some games.
You could get a Wells Gardner D9200 27" arcade monitor. It is a multi-freq monitor that can handle 15/25/31KHz. There's a patch for the ArcadeVGA that allows you to send 15 or 31 KHz signals. So in theory, you could run all the horizontal games at 15KHz, and run all the vertical games at 31KHz with a higher resolution, so they don't need to be scaled down.
I talked with a salesperson at Wells Gardner a few weeks ago and they said that they're coming out with a 25" multi-freq model sometime this year. So if the 27" is out of your price range, maybe the 25" will fit the bill.
I plan on getting the 25" model for my cab when it is available.
Krick
paigeoliver:
--- Quote from: krick on February 17, 2004, 01:55:22 am ---
Krick
I have been wary about the D9200 for quite some time. People seem to love it around here, but it seems to have quite a bad reputation in the actual industry. High failure rates apparently (one clue is the sheer number of "refurb" units they have available). Of course I wouldn't pass up one if the price was right.
I don't mind scaling things up (running low res games at VGA res), so a VGA-only monitor is fine by my book (don't want to particularly fork out an extra $100 for an arcadeVGA anyway).
But, things just keep a changing around my place.
I brought home my new games. Popeye (dedicated, working), and Gorf (cocktail, Mame, working). I had THOUGHT the Gorf was going to seem like a duplicate of my Space Firebird, but it doesn't. Turns out that MOST 8-way vertical games have two buttons, and thus the Gorf has a MUCH smaller gamelist (compare 600, to like 40).
After getting the new stuff home (and in the process losing my non-working Force II pin, which the new owner fixed in an HOUR, and my nonworking Sprint One), I rearranged EVERYTHING.
The game room is now an actual gameroom again, and not a dead game graveyard. ALL of my uprights and minis are now in there, and it is full, but not cramped. The left wall has Kangaroo, Solitaire, Galaga, and Do! Run Run, while the right wall has Out Run, Amazing Maze, Battlezone, Popeye, and my Victory pinball, while the Space Firebird is on the other wall by the door (only game I own that would fit there without making it hard to enter the room). Everything works in there now except the Battlezone, and since the Battlezone now has it's monitor installed and keyboard hacked, it should be up before this weekends party. That room is now fully dedicated to games, and no longer holds any random junk.
The Time Pilot cocktail is still serving as my kitchen table. While I put my Gorf cocktail where my main row of uprights used to be (in the living room), and my (non-working) Magical Spot cocktail is also in the living room.
I will not be keeping the Magical Spot. I will never find a board to make it dedicated again, and anything Mame would just duplicate something I already have. The only thing I could possibly do with it that wouldn't be a duplicate would be to turn it into a Pong, and I am not going to do that.
Once the Magical Spot is gone I am going to have A LOT of open living room space, which I will probably use for a table, or maybe another couch? There is still one prime spot open in there for an upright, which is reserved for my Defender when I finish it.
I have decided that Turbo, Sprint 2, and that second Defender cabinet have all gotta go. The Sprint 2 isn't nice enough for the living room, and it would take up the space of two games if I was to put it in the game room. I never did need two Defenders, that was just an accident. I made separate deals for what I THOUGHT was one Defender cabinet with sideart, and one with laminate, to be picked up from separate people the same day, I ended up getting TWO of them with sideart. I had planned on making one a Defender, and using the laminate one for Road Fighter or City Connection, but now I can't do that, because I refuse to paint over sideart. I like Turbo, but the one I have is a little beat up, probably my roughest game. I might try to clean it up before I make a final decision on it.
Soon as I move a game/cabinet for some cash I am going to finish up my Defender, upgrade the monitor size on my Solitaire (and add a spinner and a 4-way stick), and pretty much be done with this whole business.
Wade:
Paige,
The scaling problem with the ArcadeVGA you mentioned doesn't exist. I asked Andy about it and he said that vertical games are played in exactly the correct resolution as intended, when in a horizontal config. At least, that's how I interpreted what he said. Perhaps he will chime in.
Maybe you are thinking about the way vector games look on an arcade monitor?
Wade
