Author Topic: Problem with Outrun 2006  (Read 2557 times)
Gnomon
  • Last login:July 18, 2018, 05:00:22 am
« on: July 17, 2018, 03:16:24 am »
Hello,
My name is Gnomon and I am French.
I recently acquired a racecab with a pc that contains several games and with logitech G25 Wheel.
Here's a picture :
http://
Everything works well except outrun2006 with which I have a problem.
When I turn the steering wheel too far to the right or left the car spun in the other direction.
Here are my parameters in the logitech profiler:
http://
I try to change by putting the steering wheel at 271 ° but that does not change the problem.
Would you have a solution to offer me.
Sorry for my English I help with a translator.
Gnomon
buttersoft
  • Last login:April 21, 2024, 08:06:32 am
  • Is running at 15kHz
Re: Problem with Outrun 2006
« Reply #1 on: July 17, 2018, 07:19:00 pm »
Launch Outrun 2006 and calibrate the wheel in the game, making sure to hold it right the way to the end of the range each time.
Gnomon
« Reply #2 on: July 18, 2018, 05:00:39 am »
Hello,
problem solved with Howard's FXT 2.4
thank you very much
