Main > Project Announcements
javeryh's Small-ish Bartop ["Jack Attack!"]
Pages: << < (86/108) > >>
javeryh:
Revised punch list for my sanity:
* Start button modification
* Print dust washer art (possibly reprint CPO)
* Install t-molding
* Install monitor to inside of cabinet against bezel
* Polish edges of clear dust washer with Novus
* Attach dust washer art to bottom of clear dust washer
* Figure out how to control ServoStik motor with Raspberry Pi
* Create splash screen or intro video for Raspberry Pi boot
* Configure Raspberry Pi
* Wire everything
I hope to knock out a lot of this over the weekend.  Finish line in sight finally.   :cheers:
javeryh:
--- Quote from: PL1 on May 15, 2019, 12:31:17 pm ---This button would be an excellent choice.
- I've test fitted it to the Seimitsu button you're using and it will work.   ;D
- You'll need to drill or cut away at least part of the rectangle on the underside of the button cap.
- Use a small fender washer to mount the small button and some spacers underneath to hold it at the proper height inside the Seimitsu button body.
- No extra spring needed.
I got the mini button... I'm not 100% sure how I'm going to do this but I think it works in theory.  I'll have to remove quite a bit of that rectangle on the underside of the button cap somehow in order to get the mini button as high up as possible inside of the Seimitsu button.  With the right spacers, friction should take care of the rest (no need to glue everything together).  I just don't want the mini button to be able to slide around even though it will be somewhat wedged between the button cap and the bottom of the Seimitsu button.  I'll know more once I get a chance to play with it.
At the very least I want to get the monitor mounted this weekend and everything wired.  Do you guys think a strong tape would hold over time?  Ideally I'd like to just tape the monitor to the bezel from behind.  It is pretty light but I worry about the tape failing eventually.  Otherwise I need to think of some other way to do it (not to mention lining it up).
J_K_M_A_N:
is it thick enough to use a small screw and some plastic strap over the corners instead of tape? I would guess it the bezel is pretty thin. :( You could get some plastic plumbers strap if it would work.
J_K_M_A_N
Arroyo:
--- Quote from: javeryh on May 17, 2019, 03:26:48 pm ---Do you guys think a strong tape would hold over time?
I’ve used this stuff for mounting templates when routing:
It’s stupid strong, I’ve even had trouble separating two pieces pulling as hard as I can.  I can only assume it would hold up over time.
javeryh:
--- Quote from: J_K_M_A_N on May 17, 2019, 04:41:18 pm ---is it thick enough to use a small screw and some plastic strap over the corners instead of tape? I would guess it the bezel is pretty thin. :( You could get some plastic plumbers strap if it would work.
J_K_M_A_N
My bezel is made of black matte board so I can't screw anything to it, unfortunately.  It's thick (1/8") and pretty sturdy so I'm hoping tape will work...
--- Quote from: Arroyo on May 17, 2019, 05:08:01 pm ---
I've got some of that laying around - I guess I'll give it a shot.  If it doesn't work I guess that will be future me's problem.
Go to full version
